Go Back   Ford Powerstroke Diesel Forum > General Topics > Suspension & Steering
Old 08-01-2008, 06:34 AM
CloverLeafFarm CloverLeafFarm is offline
shocks
i need some shocks on my 99 superduty. what kind of shocks do you guys run that have leveling kits and 33's
Old 08-01-2008, 06:47 AM
bump !!!!!!!!!!
CHUCK CHUCK is offline
no leveling kit. I bought a set of rough country, upgraded to the nitrogen filled. Company, Top Gunz Customz, you can find them on ebay, cheapest I found.
Old 08-13-2008, 02:35 PM
Overkill Overkill is offline
If you want to improve your ride quality and never want to replace your shocks again, I would recommend these:
Bilstein 5100 - 1"-3" Front Lift Application - 1999-2004 Superduty 4wd - 5100 Series (Lifted Applications) - Truck Toyz Store
Old 08-13-2008, 10:34 PM
RC51 RC51 is offline
Do they make that shock in the s series? I have a 95 4x4 CC that I'm putting on Icon dual shock mounts and the SD mounts are shorter then the OBS ones. The truck has a 2.5" RSK kit. I have some BE-6545-H5 but I think they are to long?
Old 08-13-2008, 10:47 PM
toddy toddy is offline
I have the 5100s and love them. Definately get a set. They ride great but if you live anywhere that sees and sand or salt you need to clear coat them before you install them. They have had problems with the coating lasting in the past.
Old 08-13-2008, 10:49 PM
DunesRunner08 DunesRunner08 is offline
Marty beat me to it....I was just going to say Bilstein 5100's will be the best bang for the buck
Old 08-14-2008, 07:44 AM
Your best bet would be to get installed dimensions and then we can spec a shock specifically for your application.
Old 08-15-2008, 05:08 PM
Pahrump Pahrump is offline
5100's cannot beat them with a big stick....ride good, last a long time, look good, and are priced very well.
Old 09-11-2008, 09:04 AM
MM Billetworks MM Billetworks is offline
Not long ago I installed a set of Bilstein's on my F350 dually. Very noticeable improvement to ride! Took less than an hour to install.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
