OEM shocks on leveled truck a bad mistake? HELP! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-02-2013, 04:39 PM Thread Starter
Addicted to the Rattle
GiveMeFordOrGiveMeDeath's Avatar
So without thinking about it I installed oem shocks on all four corners of my truck which, according to the dealer I bought it from has been leveled. Am I in for trouble? Do I need to replace the shocks with appropriate lenght shocks? My truck is an 04 f250 cclb 4x4 with 143000 miles and the oem shocks have been on there for about 5000 miles. HELP!
Sent from AutoGuide.com App
Derek
*R.I.P* 2001
F250 7.3 4x2 CC SB
DIY AEM Dryflow intake, 5" Straight Pipe, TW 6pos chip.
Current Ride: 2004
F250 6.0 4x4 CCLB King Ranch. Leveled and gutted with a Walker BTM.
*MY LOVE*
2011 Harley Davidson FLHX Street Glide 103" Screamin' Eagle, stage 1 intake, stage 2 cams, Kerker Stout 4" exhaust. Custom body work and paint.
Originally Posted by alberta 7.3 View Post
If I was a superhero, I'd be "Capitan Rebound"
Originally Posted by CSIPSD View Post
And please try and spell check or something, we are not all 13 and texting.
GiveMeFordOrGiveMeDeath is offline
post #2 of 5 Old 11-02-2013, 04:49 PM
Heavy_GD's Avatar
Quoted: 1721 Post(s)
Feedback Score: 3 reviews
leveling is a 1.5" perch, shouldnt really need a lifted shock unless your shocks are over extended.
GD
Originally Posted by Patriot View Post
...because Patriot.
Heavy_GD is offline
post #3 of 5 Old 11-08-2013, 07:25 AM Thread Starter
I wasn't sure because my cab seems to move around a lot over speed bumps and through street gutters and ruts. Seems like the shocks are too soft or something, or they travel too much at low speeds and cause the tires to rub when they compress. I feel like that shouldn't happen.
Derek
*R.I.P* 2001
F250 7.3 4x2 CC SB
Current Ride: 2004
*MY LOVE*
post #4 of 5 Old 11-08-2013, 09:14 AM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
Those symptoms sound more like they are coming from the brand of shocks you are using.
But they could be blown due to not being long enough. When you have shocks that are too short, they are extending all the way when you hit bumps which will not let the axle go down far enough to give a smooth ride so the axle ends up yanking on the shock constantly which can break the shock, or even end up tearing the shock off the mounts in severe situations.
I would suggest getting a set of quality shocks that are the correct length for your leveling kit, you should notice a big difference in the ride!
Your rear shocks should be fine as far as length goes, the fronts are the issue.
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Bulletproof EGR cooler, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #5 of 5 Old 11-08-2013, 04:20 PM Thread Starter
That makes a lot of sense! They are fomoco motorcraft shocks, for stock height, and not the fancy ones, just the regular ones to fit model and year. Looks like I'll be buying some new shocks!
Derek
*R.I.P* 2001
F250 7.3 4x2 CC SB
Current Ride: 2004
*MY LOVE*
