Need help steering question - Ford Powerstroke Diesel Forum
post #1 of 11 Old 11-01-2013, 01:04 AM Thread Starter
Ak-Amarillo's Avatar
Ok my tie rod ends are getting loose on my 2006 f250. I have heard the parts called many different names. I need to know the exact name so when I order the moog parts I get the right ones. I need both ends for the tie rod assembly and the drag link. Pretty much all wearable parts from the pitman arm down. If some can give me the exact names of the parts so I can look them up that would be awsome thanks.
Ow and are moog steering parts good replacements?
Ak-Amarillo is offline
post #2 of 11 Old 11-01-2013, 01:20 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
This should help you out.... Even has the Moog part number in red.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 11 Old 11-01-2013, 01:27 AM Thread Starter
I seen that pic but the drag link in the pic ties into the tie rod. My 06 isn't like that the drag link and tie rod tie into the steering knuckle. Drag link above the tie rod that's were I was getting messed up. I've seen diagrams with part numbers but doesn't look like same set up
post #4 of 11 Old 11-01-2013, 01:29 AM
Quoted: 8 Post(s)
The pic is from an 08 but I was unaware of any changes made...
Edit: 08 is a lot different from 07 and earlier
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #5 of 11 Old 11-01-2013, 01:32 AM Thread Starter
Idk the drag link doesn't connect into my tie rod like that. Mine drag link is stacked on top of the tie rod
post #6 of 11 Old 11-01-2013, 01:40 AM
Quoted: 8 Post(s)
Does your truck have the steering stabilizer? 4x4?
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #7 of 11 Old 11-01-2013, 01:41 AM Thread Starter
Yes it has a stabilizer witch ties into the drag link not tie rod and it's a 2006 ccsb 4x4 Amarillo
post #8 of 11 Old 11-01-2013, 01:48 AM
Quoted: 8 Post(s)
Edit: Here is a link to diagrams of your front end steering setup...
http://parts.autonationfordwhitebear...ction=STEERING
Compare this to yours to make sure, you should need 4, 5, 6, and 7.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #9 of 11 Old 11-01-2013, 02:22 AM Thread Starter
Sweet is there a tie rod on the end of the drag link passenger side and would I need new adjustment sleeves
post #10 of 11 Old 11-01-2013, 02:34 AM
Quoted: 8 Post(s)
I don't think you have to get new adjustment sleeves... Unless you have a problem with yours already.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
