Making my Icon 4.5" bigger... - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-31-2013, 07:49 AM Thread Starter
So I think I can add a spacer to the front. Do I need to get the spacer from Icon or can I use any of the same type of spacer?
What do I do with the rear? Will the shocks with this kit work with the taller lift?
Thanks!
5W0P3 is offline
post #2 of 5 Old 11-03-2013, 12:31 PM
I added the Icon TEI spacer to the front and 1 inch taller blocks in the rear to my 2005 with no problems. With that being said, you may have to adjust the caster again.
4.5 Icon with TEI, 3 link arms, Carli Track Bar, 14 rear springs with PMF blocks, OUO traction bars, 325/65-18 MT ATZ on 18x10 Weld Sandstorms,5 inch exhaust, SCT with Gearhead/PHP tunes, 08 Mirrors, 08 Tailgate with BU camera, Pioneer HU, JL Stealthbox sub, Edge CTS with custom mount, Coolant filter, 5" aluminum one-piece shaft
Iron2 is offline
post #3 of 5 Old 11-03-2013, 12:37 PM Thread Starter
Adjust the caster...again? Mine wasn't adjusted in the beginning. Should it have been? It's only been on for a few months. Post a pic of your truck.
5W0P3 is offline
post #4 of 5 Old 11-03-2013, 12:47 PM
The drop brackets installed during the lift put the caster back to original. When you start adding more lift the caster will change, 1 inch would not be a big change unless it was at the low end of the specification from the factory. I will get a picture up asap.
Iron2 is offline
post #5 of 5 Old 11-05-2013, 03:50 PM
OCVeloMan's Avatar
Quoted: 179 Post(s)
Garage
You're likely going to run into issues with the length of your track bar, drag link, brake lines and need to correct your caster. I would add a .5*-1* caster shim to compensate for the additional lift.
OCVeloMan is offline
