06 F350 Track Bar Questions??? - Ford Powerstroke Diesel Forum
post #1 of 22 Old 10-26-2013, 02:08 PM Thread Starter
MHCRRA16's Avatar
Hi all,
So, I am still working on getting my new to me 06 F350 ready for the road....This is a truck I bought already lifted and already with big tires/wheels, etc. So I don't know much about the history or components......
My question today is this....according to the attached photos, does this track bar look like it's bent/damaged???
I am assuming that it is NOT the factory track bar since it has the adjustable section on the upper mount. It has the curve in it down towards the axle, but it looks to me that the threads are BENT up by the adjusting collar. Is this a normal bend? Is it designed that way?? I have read on here that track bar issues can cause death wobble and all sorts of problems so I want things to be right when I get it on the road.
Here are some photos of the track bar and I have circled where the bent section is.
Thank you for any help and all suggestions.
Rob
Name:	20130911_174941 (1024x768).jpg
ID:	187361   Click image for larger version
Name:	20130911_174954 (1024x768).jpg
ID:	187369   Click image for larger version
Name:	20130911_175013 (768x1024).jpg
MHCRRA16 is offline
post #2 of 22 Old 10-26-2013, 02:21 PM Thread Starter
MHCRRA16's Avatar
Also.....if I have to replace this one....what brand do you guys recommend for an adjustable track bar??
MHCRRA16 is offline
post #3 of 22 Old 10-26-2013, 03:24 PM
Quoted: 50 Post(s)
Yes, the track bar does look bent at the adjuster. I have an Icon track bar and it's fine. I've heard lots of good things about the Carli track bar as well.
Also, it looks like sway bar end links are way too short for the amount of lift you have. The sway bar arms should normally be parallel with the ground.
I would have your front end looked at by a good off-road shop that knows Super Dutys.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDC Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #4 of 22 Old 10-28-2013, 08:59 AM Thread Starter
MHCRRA16's Avatar
Thanks for the input....you confirmed what I had suspected. Time to order a new track bar!!
'06 F350 CCSB
Pro Comp 8" (maybe) Lift
20" Massey Hulk
37x12.5x20 Pro Comp Tires
A LOT of unknowns...work in progress...
Newly acquired...who knows what else has been done to this poor truck....
Stay tuned
MHCRRA16 is offline
post #5 of 22 Old 10-28-2013, 11:04 AM
OCVeloMan's Avatar
Quoted: 151 Post(s)
Garage
WOW.... that track bar looks super old and definitely bent... What size is the lift on there?
OCVeloMan is offline
post #6 of 22 Old 10-28-2013, 12:47 PM Thread Starter
MHCRRA16's Avatar
To be perfectly honest, I'm not really sure what size lift is on it??? I bought it that way and the previous owner says it's a 12" Pro Comp lift...but according to Pro Comp, they never made a 12" lift. I know it's Pro Comp because it has the "Pro Comp" logo radius arms....other than that I don't know much about it. I'm trying to get things figured out and in as good a condition as I can before getting it on the road for winter. I think I'm going to go with a BD adjustable track bar and a new OEM ball joint. The track bar looks almost parallel to the drag link which is a good thing.....
MHCRRA16 is offline
post #7 of 22 Old 10-28-2013, 12:55 PM
OCVeloMan's Avatar
Quoted: 151 Post(s)
Garage
May want to check out our track bar... The BD will use a bushing which will wear pretty quick. On our bar, there's nothing to bend. It's a chromoly track bar with an FK bearing at the frame mount connection. What is the measurement of the ICON bar on the truck? (center of eye to center of eye)
post #8 of 22 Old 10-28-2013, 01:39 PM Thread Starter
MHCRRA16's Avatar
OCVeloMan....that's a good question, I will measure it up tonight and get back to you. I was mainly going with the BD because it fit into my budget....I'm already dropping more than I expected. Can you tell that is an ICON brand on the truck from the photos??
Rob
MHCRRA16 is offline
post #9 of 22 Old 10-28-2013, 05:40 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
Do your coil springs have 2-3" thick spacers on top of them? It looks to me like someone either added spacers or taller springs to the procomp lift that is on there to increase the height. That would also explain why the sway bar mounts are too short.
And I see a bracket clamped to the center of the axle housing, is it connected to anything? That is where a double steering stabilizer kit would clamp on.
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #10 of 22 Old 10-28-2013, 06:08 PM Thread Starter
MHCRRA16's Avatar
Greg you are exactly correct....someone did indeed install 3" spacers on top of the front coil springs....the springs have a bow as well...I think the shocks might be topped our y causing the bow.
I plan to take those spacers out and install the factory isolators and to take one of the 3 bucks out of the rear to make it level.
I think that will bring things better into line in the front geometry and put the seat bar back into being parallel with the ground.
Since that track bar is junk I need to replace it with a new adjustable anyway.
The bracket was indeed for a dual stabilizer setup that was broken off...I have a new one waiting to go on once I get things cleaned up.
Thanks Rob
'06 F350 CCSB
20" Massey Hulk
Stay tuned
MHCRRA16 is offline
