1.5 inch add-a-leaf? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-22-2013, 05:45 PM Thread Starter
I have a 1997 7.3L ford f250 4wd that is completely stock. I talked my dad into ordering me a leveling kit (im 16) and he ordered a 1.5 inch tuff country add a leaf. I think it will still be nose diving once we add it and I thought we needed a 3 inch because the front is 3 inches lower. Im no genius so Im not sure. I would also like to add 33inch toyo open country mt's and Im not sure. Help me out? thanks
JarrettKA is offline
post #2 of 5 Old 10-22-2013, 05:58 PM
truckyard1's Avatar
Quoted: 18 Post(s)
I've got a tuff country on mine, if you have worn springs it won't level out but it will raise it a good bit. Also makes the ride rougher. I fit my buddies 31's on my truck, that's the biggest I've ever run
Sent from AutoGuide.com App
Rob
'95 F350 CCLB, "Project Moneypit", ZF5, 4x4, straight piped, DIY E-fuel, more coming
'63 Jeep Truck, Chevy motor, Ford 9"
truckyard1 is offline
post #3 of 5 Old 10-22-2013, 06:02 PM Thread Starter
well right now I already have 31s and they are kinda close. but im hoping this will allow me to fit 33s
post #4 of 5 Old 10-22-2013, 06:25 PM
alaskan155's Avatar
Quoted: 60 Post(s)
thats all your going to get out of the ttb, anything more than 2" is going to require drop brackets in the center.
with a add a leaf up front it is going to ride harsh btw....the ttb(said you had a 250) leafs are already negative arc, which is normal for ttb.
honestly if you want more lift i would start looking for a dana 60 and do a RSK, if you cant find one PMF makes a RSK that is offset to allow you to bolt in a superduty dana 50/60 from a 99-04, then you can run the better superduty springs or F350 front springs
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #5 of 5 Old 10-24-2013, 10:55 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 465 Post(s)
Garage
I used a add a leaf years ago and it was horrible. It made the suspension so stiff that the frame was more flexible. I soon had dents behind the cab from the bed hitting it from frame flex. It raises it alright but WOW was it stiff.
No they did not stay on truck for long.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
Tags
1997 , f250 , f250 7.3
