Need Part #'s for 2005-2008 F350 Radius Arm Bracket - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-20-2013, 05:55 PM Thread Starter
5fifty's Avatar
Looking for anyone that has a 05 to 08 F350 4x4 with stock suspension. I need the part numbers of the radius arm brackets to cross reference.
TIA
2005 F-550 4x4 22.5's
Kelderman Air Ride
Bulletproof Diesel Remote Oil Cooler W/F550 Cooler
Bulletproof Diesel Billet Water Pump
Bulletproof Diesel Radiator
Dieselsite Wicked Wheel, Dieselsite Coolant Filter Kit
Warren Diesel 155/30, Bluespring Mod, 6.4 Banjo,
Updated STC, Turbo Feed and Drain Tubes,
PMM EGR Delete
SCT Tuner, Edge Insight w/EGT, Fuel and Oil Pressure
Tuned By MATT @ Gearhead Automotive Performance
5fifty is offline
post #2 of 6 Old 10-21-2013, 03:02 PM Thread Starter
5fifty's Avatar
TTT... Just need the numbers that are stamped in the side of the brackets..
Kelderman Air Ride
PMM EGR Delete
5fifty is offline
post #3 of 6 Old 10-21-2013, 09:48 PM
I just received 2 new radius arm bracket from Tousley Ford to do my 05 axle swap on my Excursion.
Model year F250-F550
This is the part# stamped on the bracket;
3C34-3B095 --Passenger side
3C34-3B183 --Driver side
This is the part# on the box;
5C3Z-3B095-AC
5C3Z-3B095-BA
I'm new and not setup for pictures, or else I'd put it up.
00X7.3PSD is offline
post #4 of 6 Old 10-22-2013, 03:05 PM Thread Starter
5fifty's Avatar
5C3Z-3B095-AC
5C3Z-3B095-BA
Does it say F250 -550 on the box?
Kelderman Air Ride
PMM EGR Delete
5fifty is offline
post #5 of 6 Old 10-22-2013, 04:04 PM
It written on instruction sheet. If you call Ford dealer, I think they can verify if part number will fit all f250-f550. I know part# will fit f250-f350.
post #6 of 6 Old 10-22-2013, 04:15 PM Thread Starter
5fifty's Avatar
Ok cool thanks for the info. I have to go over there tomorrow so I will cross reference them. It is usually a pain to deal with them but hopefully I can get a good answer.
I assume the adjustable track bar will fit too.. hopefully.
Kelderman Air Ride
PMM EGR Delete
5fifty is offline
