What is this seal apart of? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-16-2013, 11:13 AM Thread Starter
usteffenhagen's Avatar
This seal or whatever is just free spinning, not connected with anything. The one on the other side is the same. It's just on the inside of the axle u joints.
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #2 of 6 Old 10-16-2013, 12:16 PM
Quoted: 184 Post(s)
Feedback Score: 3 reviews
It's actually perfectly normal, for us anyway
Because there's no support for the axle, at the end of the tube, there's a surprising amount of movement there. So, that's called a "Dust Shield" and does little more than prevent small pebbles from entering the tube and jamming in. The seals that hold the Diff Fluid are way inside at the center section...
If you replaced them with new they'd look like that again in not too long.
NoRalPh is offline
post #3 of 6 Old 10-16-2013, 12:37 PM Thread Starter
Good to know. I figured it was some kind of dust seal but didn't wanna sound like an idiot if I was way off lol. Thanks for the info I'm learning something new everyday
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #4 of 6 Old 10-19-2013, 10:34 PM
snafu!'s Avatar
There is an updated seal that presses into the axle tube, but its not worth replacing unless your replacing ball joints or u joint.
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #5 of 6 Old 10-19-2013, 10:43 PM Thread Starter
Is it a Ford product?
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #6 of 6 Old 10-19-2013, 10:44 PM Thread Starter
Nevermind, I don't know why I asked that.
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
