Slight pull to the right??? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 10-15-2013, 07:13 AM Thread Starter
Dante Supreme's Avatar
So I had the alignment done and the pull has gotten much better but its still there, they had suggested camber/caster kit but everything is in spec.
Any ideas?
06 F350 CCLB Lariat FX4
MBRP 4" TB
Insight+Pyro
SCT+Vivian Looney
Blue Spring
XDP Coolant Filter
XDP EGR Delete (coming soon)
Dante Supreme is offline
post #2 of 12 Old 10-15-2013, 08:58 AM
Pure Perf's Avatar
What tires, steering stabilizer, and cross caster are you running?
JP
www.pure-performance.biz
Pure Perf is offline
post #3 of 12 Old 10-15-2013, 10:06 AM
luke7.3's Avatar
Quoted: 24 Post(s)
You're probably not going to get rid of that pull unless you get new tires. I had a pull to the right when I had Dick Cepecs and when I got a new set of BF Goodrich the pull disappeared. It could be a variety of different things though.
luke7.3 is offline
post #4 of 12 Old 10-15-2013, 11:51 AM Thread Starter
JP
Stock 20" wheels and general ht/s tires that are new, completely stock suspenders and steering.
But my tires are new.
MBRP 4" TB
Insight+Pyro
SCT+Vivian Looney
Blue Spring
XDP Coolant Filter
post #5 of 12 Old 10-15-2013, 04:17 PM
luke7.3's Avatar
Quoted: 24 Post(s)
Most trucks will get that pull. You're best bet is to have a suspension expert look at it. New tires fixed my pull so IDK about yours.
Luke
97 F250 CCSB 4 inch straight pipe, 6637 intake, TS 6 pos (daily)
08 F350 6.4 Reg Cab flatbed Spartan tuned, AFE Intake, DPF/DOC Delete(work truck)
luke7.3 is offline
post #6 of 12 Old 10-15-2013, 05:37 PM Thread Starter
Why would most trucks get that pull?
I had an alignment done at a shop that does mostly big and lifted trucks and they recommended a camber caster kit.
MBRP 4" TB
Insight+Pyro
SCT+Vivian Looney
Blue Spring
XDP Coolant Filter
post #7 of 12 Old 10-15-2013, 05:49 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Is it because of the crown in the road? Does it happen when you are driving in the opposite lane? Like while passing another vehicle on a 2 lane hwy...
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #8 of 12 Old 10-15-2013, 06:03 PM
luke7.3's Avatar
Quoted: 24 Post(s)
I guess the suspension wears out and the crown in the road has a lot to do with it. All my trucks have had it in their life. Just gotta get used to tilting the steering wheel a little to the left!
Luke
luke7.3 is offline
post #9 of 12 Old 10-16-2013, 10:04 AM Thread Starter
Negative
I hate that
MBRP 4" TB
Insight+Pyro
SCT+Vivian Looney
Blue Spring
XDP Coolant Filter
post #10 of 12 Old 10-17-2013, 07:54 AM
Skyd Ram's Avatar
Quoted: 140 Post(s)
I don't know anything about that specific tire but I am going to guess that it is a side effect of the tire design. Many tires on the market will have a right pull while a small amount have a left pull. If the pull is mild it can be adjusted for by running more caster on one side of the truck (cross caster). The amount of cross caster that can be put in a solid axle vehicle is minimal so it may not be enough to correct for those tires.
Another way to counteract for the right pull is to use a high pressure stabilizer that "pushes" to the left. Carli makes a unit like this for the 2008+ trucks that does very well. They hope to have a version out for the 05-07 trucks in the future but it will be quite a while due to all of the other development work they have right now.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is online now
