Go Back   Ford Powerstroke Diesel Forum > General Topics > Suspension & Steering
Old 06-29-2008, 09:11 PM
Goolsbymd Goolsbymd is offline
Project Abused
37X13.50 on 20 w/ 6"
Pretty sure I will clear pretty easly just not at full lock left/right correct?
Old 06-29-2008, 10:17 PM
Jordon Donald Jordon Donald is offline
you'll be fine ... a friend of mine runs that size on a 6inch... just do yourself a favour and get a big offset on your rims. i run 37x13.5x18 on a 4inch with bushwacker cutout fender flares and i could easily do a 38.5 with no chance of rubbing. it just sucks with leafs but i'm looking to do the fabtech coilover conversion to eliminate that problem.
Old 06-30-2008, 07:01 AM
Pahrump Pahrump is offline
It will work...I had that combo first.
If it rubs anywhere it will be at the back of the fenders towards the doors.
Easy fix, you can lay under the truck and actually push the fender liner back towards the door, theres about 1/2" of movement there, and then put a self tapping screw in there to hold it...works like a charm and no cutting needed.
I dont think 38's will fit...I have 38x15.50's on my 08 now, with almost 9" of lift, and if I turn ALL the way, and go thru a sharp transition driveway or something where the road goes down then up, it will slightly rub.
Old 06-30-2008, 07:02 AM
BTW I see you are putting the Revolvers on...my cousin has those on his truck..good looking wheel.
This is his truck with 6" and 37x13.50x20 with the 20x10 Revolvers.
Old 07-04-2008, 10:06 AM
ridetillurdead26 ridetillurdead26 is offline
We need more opinions in here! I'm looking to do the same thing. Can someone post with 35's?
Old 07-04-2008, 10:12 AM
DunesRunner08 DunesRunner08 is offline
I have 12" of lift with 40's so my pics won't help you
Old 07-04-2008, 10:23 AM
Why would you even bother posting that? Just to be cool and get your little post count up? Sweet....
Old 07-04-2008, 10:27 AM
gotta get my post count up...I've been slacking for a few months......lol
Old 07-04-2008, 11:03 AM
6" with 35's dont look good IMO...too small
Old 07-04-2008, 12:01 PM
READNECK READNECK is offline
have a 2002 with 37's and a 6" lift rubs the inner fender a little, a little trimming fixed that. had to put wheel spacers on so it wouldn't rub on the leaf spings. so make sure you get the right offset wheel.
