Suggestions to improve zone 6" lift - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-01-2013, 07:09 PM Thread Starter
scummins's Avatar
I have a zone 6" lift on my 2011 f-250. I should have gone with my gut and went carli, but here I am. Had a deal too good to pass up . Tires are toyo mt 37x13.50 18's on 18x10 wheels. The rear is worse than the front. It has the 2 add a leafs on each side on 5" blocks. The suspension is very harsh thru the stroke but is not bottomng out. It has the nitro shocks which already look like they leaked out some oil. I'm thinking fox 2.0 shocks or something similar to start and if that doesn't do wonders, a deaver spring pack. Who else make a good shock that will work with a 6" lift?
For the front I'll do new shocks and possibly new coils. Any suggestions on that?
Thanks for any input.
And for anyone that asking is the price worth going carli or icon, etc....yes... learn from me lol
11 Lariat
6" lift, 37's, Moto Metals, H&S, SPE, JL SPL2K
scummins is offline
post #2 of 5 Old 10-02-2013, 09:50 AM
Skyd Ram's Avatar
Quoted: 128 Post(s)
That kit has the following items working against you. You can fix one or 2 of them but until you do all of them you won't see massive ride improvements:
1) Stiff single rate coils
2) Stiff add a leafs
3) Cheap shocks
4) No drop bracket for radius arms
I would start with replacing the 2 add a leafs with either a set of Mini Packs or full replacement leafs like Carli's.
Then replace the shocks with either a set of Bilsteins or Pure Prodigy shocks
To improve the front I would swap out the coils for a set of 6" Pure progressive rate coils. If it is still stiff up front I would go with a set of radius arm drops and factory radius arms or do a Pure 4-link conversion.
In the end it may be better to just replace the whole kit and sell the Zone kit to offset some of the cost.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is offline
post #3 of 5 Old 10-02-2013, 12:53 PM
Quoted: 6 Post(s)
I agree with above, never go with anything besides a progressive rate coil.
2006 F250 CC/SB 6.0 Diesel
SCT 3015, Straight Piped
2002 F350 CC/SB 7.3 Diesel- SOLD
-PHP Hydra, 6637, Diamond Eye DEP-510215 Muffler Delete, GlowShift Triple Gauge Cluster.
-Plans: JW Valve Body & 6.0 Torque Converter/Cooler
bikeluver43 is offline
post #4 of 5 Old 10-02-2013, 04:45 PM Thread Starter
scummins's Avatar
Thanks Skyd,
Are you a dealer for those companies? if so, maybe you can shoot me some prices. I appreciate the input.
3) Cheap shocks
11 Lariat
scummins is offline
post #5 of 5 Old 10-02-2013, 08:52 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
You usually get what you pay for.
I had a rough country 6" cheap lift on my truck and it was horrible.
I put I-Con progressive coils up front.
Dumped the drop brackets and oem radius arms.
Went with Fabtech radius arms was a huge improvement with handling, truck tracked straight no longer wandered on bad roads.
Dump the overloads for sure.
Get a drop bracket for track bar. That needs to be at the same angle as the drag link to prevent bump steer.
I got Rancho RS9000XL for the reason of (adjustability) love em.
You go this route and you will have a much better truck.
I also did a rear spring mod that spaced overload away from spring pack to smooth out rear suspension.
My truck rides as nice as wife's Tahoe. Most likely best riding F250 in California ��
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is online now
