Camber bushings - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-01-2013, 04:06 PM Thread Starter
HOUTX01X's Avatar
Quoted: 4 Post(s)
Camber bushings
Where can I find aftermarket bushings for 2011 f250 4x4 with leveling kit.
I've found some but the year stops at 2010.
Alignment shop couldn't get it squared way without them so it still I'll to right a hair.
Thanks
Will any of these work?
camber/caster parts
'11 F250 KR
XRT Pro, H&S SX-E turbo kit, NoLimit intake/intercooler
OUO bars/blocks
-EGR,CCV,1993pf
Leveled w/ 35 atII
HOUTX01X is offline
post #2 of 6 Old 10-01-2013, 04:14 PM
Quoted: 28 Post(s)
Caster not camber
06 350 CCLB
Edge CTS
Up-Pipes by Cutting Edge
ARP's
Bulletproof EGR Cooler
Coolant filter
rentstdi is offline
post #3 of 6 Old 10-01-2013, 05:25 PM
WoodBoy's Avatar
How big a leveling kit? 2.5"?
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #4 of 6 Old 10-01-2013, 06:09 PM
Quoted: 28 Post(s)
Adjustable track bar?!?
06 350 CCLB
Edge CTS
ARP's
Coolant filter
rentstdi is offline
post #5 of 6 Old 10-01-2013, 06:22 PM Thread Starter
HOUTX01X's Avatar
Quoted: 4 Post(s)
I believe so... It was on when I bought it...
I saw the track bars.. Would that do the same..solve my problem..
My steering wheel is slightly rotated to right.. The same direction it pulls.
It's not to bad but want to get it fixed before I get new tires.
'11 F250 KR
OUO bars/blocks
-EGR,CCV,1993pf
Leveled w/ 35 atII
HOUTX01X is offline
post #6 of 6 Old 10-02-2013, 05:21 AM
WoodBoy's Avatar
Track bar realigns your axle to the center of the truck. Pulling left or right usually means the alignment is out. Caster being out which it probably is some, usually doesn't pull left or right on flat ground, but rather follows the curvature of the road and maybe some bump steer.
You should call trevor at Precision Metal Fab. I know he has some replacement radius arm brackets made for 2.5" and on up. I would do that before I done caster bushings because I don't know if the caster bushings will give you enough
WoodBoy is offline
