death wobble - Ford Powerstroke Diesel Forum
post #1 of 11 Old 10-01-2013, 06:58 AM Thread Starter
panteramatt's Avatar
Quoted: 37 Post(s)
death wobble
I was driving my 2000 psd yesterday and hit a bump and had a TERRIBLE wobble in the steering wheel til I slowed down then went away til I hit the next big bump. The only thing Ive changed lately was the drivers side tie rod end and calipers. I set it at 1/4" toe in and it drove fine for a few days. Sat for 4 days and went to drive it and now this happens.
panteramatt is offline
post #2 of 11 Old 10-01-2013, 07:15 AM Thread Starter
Quoted: 37 Post(s)
After searching it looks like tire pressure is the #1 cause. I read you should have 60psi but my tires call for 50 max. Im running 40 right now. What should I set them at?
post #3 of 11 Old 10-01-2013, 05:26 PM
WoodBoy's Avatar
I don't see tire pressure being the cause bud. Do you have any suspension mods?
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #4 of 11 Old 10-01-2013, 05:45 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
Its not the tire pressure I run my fronts at 29 psi and rears at 25 and its not a issue.
How is the front end, is there any play in the steering wheel. A loose steering box can lead to it so can a bad alignment. Loose ball joints etc, anything loose can set it off.
Some negative caster helps control it as well. I was dealing with it on my truck and adjusted in some more negative caster and it cleared mine up but different things can cause it.
How is your stabilizer shock? This of coarse masks it but a bad stabilizer will open you up to it much easier.
Check the steering wheel play, start at the steering box if there is play.
Good Luck with it.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
post #5 of 11 Old 10-01-2013, 09:14 PM Thread Starter
Quoted: 37 Post(s)
Sorry I thought it was in my sig. I have a 6" lift and 37" tires. Ive had it on there for years and all was fine. I dont have a stabilizer but never needed one either. Theres not much play in my steering. How would I check the steering box? Could it be an alignment?
post #6 of 11 Old 10-02-2013, 05:23 AM
WoodBoy's Avatar
Something is loose/worn somewhere. You need to get under your truck and check every component to do with steering and the front axle. Check bushings really good. Get someone in the truck to turn the steering wheel back and fourth and watch for play
WoodBoy is offline
post #7 of 11 Old 10-02-2013, 06:35 AM Thread Starter
Quoted: 37 Post(s)
I replaced the worn tie rod end but everything else seems fine. Ill check the steering box.
post #8 of 11 Old 10-02-2013, 06:54 PM
897.3alltheway!'s Avatar
Quoted: 11 Post(s)
check your alignment , happened to be and found out i was towed in way to far
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
post #9 of 11 Old 10-02-2013, 08:40 PM Thread Starter
Quoted: 37 Post(s)
It did happen after I replaced the tie rod end but I set it at 1/4" so it should be fine.
post #10 of 11 Old 10-03-2013, 01:56 AM
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
I'm going to guess its a alignment issue, you said 1/4 toe in ?
May be too much, I agree with above post I too experienced it also myself when it was misaligned.
7" Icon/Carli Lift
Atlas40
mhatlen is offline
