My Death Wobble Fix - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-30-2013, 06:07 AM Thread Starter
My Death Wobble Fix
Current suspension: 4.5 DR with TEI spacer, DR Adjustable Track Bar, Dual stabilizer, ORU 3 Link Arms, less than 20K on new ball joints and steering linkage
Never had a problem until a couple months ago. Started to get the wobble if I hit a bump with mainly the passenger side tire.
Had Caster set at 3.5 degrees and changed that to about 4.2. That helped about 65 percent.
Decided to change out the DR track bar (with bushing end) with the Carli track bar. Figured the bushing was shot and wanted to upgrade to the Carli bar. Changed out the track bar balljoint at the same time.
It is solid as a rock now. I don't remember it ever steering this good. I believe the track bar bushing was the main issue, but adding the caster certainly helped.
4.5 Icon with TEI, 3 link arms, Carli Track Bar, 14 rear springs with PMF blocks, OUO traction bars, 325/65-18 MT ATZ on 18x10 Weld Sandstorms,5 inch exhaust, SCT with Gearhead/PHP tunes, 08 Mirrors, 08 Tailgate with BU camera, Pioneer HU, JL Stealthbox sub, Edge CTS with custom mount, Coolant filter, 5" aluminum one-piece shaft
Iron2 is offline
post #2 of 9 Old 09-30-2013, 06:58 AM
Good information! That more positive caster helped is a positive argument against using just a coil spring spacer to level a truck. Just a spacer will take caster out of the front end.
Karl and his 03
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #3 of 9 Old 09-30-2013, 07:32 AM
my death wobble is returning also, where do we find the Carli track bar and how much$?
jonF-250 is offline
post #4 of 9 Old 09-30-2013, 10:12 AM Thread Starter
I bought mine at 8 Lug Truck Gear 345.00 with free shipping.
Iron2 is offline
post #5 of 9 Old 09-30-2013, 10:35 AM
thanks man !
jonF-250 is offline
post #6 of 9 Old 10-18-2013, 07:38 PM
kirbybc12's Avatar
Just curious as to some of the abbreviations such as ORU and DR. Which dual stabilizers did you go with?
2012 F-350 Lariat FX4 CCSB
2.5" Carli Commuter
Carli High Mount Steering Stabilizer
AFE Cold Air Intake
Truxedo Lo Pro QT
Line-X
Dura-Flap Mud Flaps
Timbren SES
High Idle
35x12.5x20 Toyo AT II Extreme
H&S Mini Maxx, 4" AFE Turbo Back
kirbybc12 is offline
post #7 of 9 Old 10-18-2013, 10:05 PM
You could identify which model and year truck
JohnDS is offline
post #8 of 9 Old 10-19-2013, 06:06 AM Thread Starter
2005 F250 CC 6.0
DR Donahue Racing, now called Icon.
ORU should be OUO One Up Off-road.
I ended up using a dual stabilizer kit from PMF, it was on sale.
Iron2 is offline
post #9 of 9 Old 10-20-2013, 06:42 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 465 Post(s)
Garage
I had a pretty bad case of death wobble when I adjusted my
Fabtech radius arms to the negative side of the washers. The coils sure sat straight up and down but the death wobble was immediate when I changed it.
So yes you are correct that caster can cause death wobble, I have seen what it can do in my truck.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
