05 f250 front end trashed - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-28-2013, 06:24 PM Thread Starter
Ok so long story short I bought an 05 f250 with a trashed front end ball joints, tie rods bearings, etc the dam thin jumps when I hit a bump just right and won't stop till I stop the truck I was looking at auto zone and orileys they want 1500+ for parts and I know I was missing a few things when I priced it all out
I know there are some good respetible online stores out there that I can get what I need cheeper Can anyone point me in the right direction
And what should I all be replacing I know upper and lower ball joints ,tie rods ,updated dust seals ,and hub bering assembly if they are bad. I know there has to be something I'm missing so what would it be ?
Moon545 is offline
post #2 of 4 Old 09-30-2013, 06:27 PM Thread Starter
Going to get all the parts tomrow here is my new list
Upper/ lower ball joints
Torsten bar ball joint
Tie rods
Axel shaft dust seal
Shocks
Sway bar
Hub assembly
And a rear leaf spring
I'm going to take lots of pictures and post them upb
Moon545 is offline
post #3 of 4 Old 10-01-2013, 05:46 AM
Quoted: 3 Post(s)
Rockauto has good prices
11 F250 CCSB King Ranch
Gearhead tunes, No Limit Stage 2, No Limit Block Off, 5" exhaust, CTS
2.5" Carli Commuter, 37x12.5R20 Toyo RTs, Stock wheels
01 Ex 7.3l Limited
Swamps tunes, 6637, 4" exhaust, 6.0 trans cooler, Hellwig rear swaybar, CTS
06 headlights
bigred3297 is offline
post #4 of 4 Old 10-01-2013, 06:01 AM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 6 Post(s)
Use quality parts Moog,Timken. Replace both front hubs while its apart, if everything is as bad as you say don't leave anything to chance. If you spend $1000 on new tires with a so so hub' pay now or pay later ,besides everything goes together a lot easier when all is new . I did my whole front end for $873 and she's as tight now as new.
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is offline
