Steering wheel play - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-27-2013, 06:52 AM Thread Starter
Steering wheel play
I have a 97 f250 and it has a lot of play in the steering. Any ideas what this could be? Steering box maybe?
X4x4danx is offline
post #2 of 3 Old 09-27-2013, 08:20 AM
WoodBoy's Avatar
Worn out parts like bushings and etc should be checked, could be the steering box. This is more or less a diagnosis in person you need to do. Get under your truck and get someone to turn the steering wheel back and forth in the area of no resistance (play area), while they are doing this you need to be looking at everything. Drag link, pitman arm, tie rod ends and look for play. If you see no play, then you should look into the steering box
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 3 Old 09-28-2013, 08:21 AM
Have you tried adjusting the box? There is a hex head and a lock nut on top of the box, loosen the lock nut, run the hex in, then back it out about 1/2 a turn, then lock it down. Take it for a ride, it may need a second adjustment.
Everytime I have done this, hot rods, 4x4s, daily drivers, whatever, it makes a positive improvement to the steering quality. HOWEVER, this will not fix worn knuckles and ball joints. But it is a good first step in trouble shooting.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
