Saginaw power steering pump upgrade - Ford Powerstroke Diesel Forum
post #1 of 23 Old 09-25-2013, 06:11 AM Thread Starter
Ok my old Ford power steering pump is dying and I was looking into the option of upgrading to a Saginaw pump. I have see recommendations to do this upgrade but not very many details. Such as:
1) Which Saginaw pump would be the easiest to install on the 7.3 powerstroke engine?
2) Who carries these pumps?
3) Do you continue to run ATF or switch to power steering fluid since this pump also supplies a hydroboost system?
Thanks for your help!
NCC-1701 is offline
post #2 of 23 Old 09-25-2013, 07:10 AM
Quoted: 897 Post(s)
Feedback Score: 3 reviews
Corey@CNCFAB is offline
post #3 of 23 Old 09-25-2013, 11:12 AM Thread Starter
Thanks for the feed back. I called these guys a couple of days ago. They advised me to stick with the stock Ford pump!
NCC-1701 is offline
post #4 of 23 Old 09-25-2013, 12:30 PM
layson's Avatar
Quoted: 84 Post(s)
You never know what you are going to get with those guys. Sometimes they will quote you a kit and other times they won't...LOL
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #5 of 23 Old 09-27-2013, 05:09 PM Thread Starter
Bump
Any ideas on the PS pump part number that has a ford bolt pattern?
What about the fluid after the switch to saginaw pump. ATF or PS fluid?
Thanks!
NCC-1701 is offline
post #6 of 23 Old 09-27-2013, 07:40 PM
Quoted: 5 Post(s)
Check out the AGR Super Pumps @ agrperformance.com They make a very good product.
renegade99 is offline
post #7 of 23 Old 10-01-2013, 03:55 PM
Motomez's Avatar
Talk to PSC about the Hydra Assist I have had mine for 3 years with No problems. The truck turns with 1 finger and the cool part is you don't need a steering dampener as the Rack works like a steering dampener.
2002 PHP Hydra Chip, Banks Monster Exhaust John Wood Transmission 6.0 Cooler 06 front Axel Pure Performance 6 inch lift and 4 link 08 Rear springs Fox Racing 2.0 Piggy Back Shocks Raceline Renegade 8 wheels with 35 Toyo RT's Auto Meter Gages PSC Hydro Steering Dorman Bellowed up pipes Ford AIS 08 Tow Mirrors
Motomez is offline
post #8 of 23 Old 10-02-2013, 05:19 AM
broncomitch's Avatar
Normally with hydro assist the turning is pretty slow, ( in my case off road obstacle course type stuff)
How is the resistance when your trying to turn fast?
L99 f250 7.3 powerstroke,
L99 hybrid turbo,
Built transmission,
TS, 6 position chip,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
FPR alum housing with black spring,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
06 axles and suspension,
09 steering box,
015 spring swap and shackle flip.
Saginaw PSP conversion,
016 front bumper,
Autometer&Torque app for gauges,
71 early bronco "rock crawler" 351w,c6,strong box,np205,1tons, 44"tires, ect ect.
broncomitch is offline
post #9 of 23 Old 10-02-2013, 05:48 AM
Motomez's Avatar
There is a little more resistance when I turn fast but I will live with that over not being able to turn at all with the stock setup.
Motomez is offline
post #10 of 23 Old 10-02-2013, 11:05 PM
codyryan07's Avatar
Originally Posted by NCC-1701 View Post
Bump
Thanks!
I wanna say the 6.9 vans had them. And of course some olders. You'll have to either make a custom bracket or modify your current PS bracket. I've got a pump laying in my shop, but no extra bracket to try and work with. Around here the JY want around $200 for the bracket off a superduty
Cody Ryan
03 f250 ccsb fx4 7.3
4" RC lift
35x12.50 federals on 20x12 rockstars
6637 intake, straight pipe
full RR w/ fuel bowl delete.
rebuild coming soon
codyryan07 is offline
