2005 f-250: 2" or 2.5" or 3" leveling kit - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-21-2013, 10:27 AM Thread Starter
break it. fix it. repeat.
Mr. Projekt's Avatar
Quoted: 32 Post(s)
Garage
Send a message via AIM to Mr. Projekt
hey guys just wondering since i'm trying to level out my 05....
it measures 39.25" in the front and 41.75 inches in the rear...
but eventually i want to go with a 1-2inch block in the rear.... (but that wont be at the same time as the leveling kit.)
so basically i want something that will make it level but still give me some clearance.... what size should i go with?
thanks in advance
Caleb
Centennial State Powerstrokes
I sold my truck for a Toyota
Mr. Projekt is offline
post #2 of 3 Old 09-21-2013, 07:40 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
Go with the 7" lift along with some 38/15.50/18 tires and be done with it.
Looks like your well accustomed to that lift range by looking at your signature
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is online now
post #3 of 3 Old 09-22-2013, 10:56 AM
I had the camburg kit on my 06 350 initially and it was still noticably higher in the rear. I swapped the 2" coils for 2.5" Icon coils and my truck is just about perfect for my tastes. The rear is just a bit higher than the front. But I have a 350 with the factory overloads and blocks.
w00ht is offline
