icon vs. pmf front lift - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-18-2013, 05:58 PM Thread Starter
BLACKDUALLY's Avatar
I noticed a lot of people are running pmf rear lift for better traction, towing and less axle wrap, but on the front people are running icon, is icons front set up for an 04 f350 4" hangers with 4" leafs that much better than the pmf front hanger and leaf set up? not including shocks im just talking about hangers and leaf springs.
BLACKDUALLY is offline
post #2 of 6 Old 09-19-2013, 08:11 AM
Quoted: 3 Post(s)
PMF doesn't make leaf springs, this would be why nobody has a leaf spring front end lifted by them.
11 F250 CCSB King Ranch
Gearhead tunes, No Limit Stage 2, No Limit Block Off, 5" exhaust, CTS
2.5" Carli Commuter, 37x12.5R20 Toyo RTs, Stock wheels
01 Ex 7.3l Limited
Swamps tunes, 6637, 4" exhaust, 6.0 trans cooler, Hellwig rear swaybar, CTS
06 headlights
bigred3297 is offline
post #3 of 6 Old 09-19-2013, 08:35 AM Thread Starter
Thank you, I didnt know, I was looking at their 8" lift it said a 4in shackle with a 4" spring, do you know what they use for that kit?
post #4 of 6 Old 09-19-2013, 09:06 AM
layson's Avatar
Quoted: 82 Post(s)
Just go with the Icon setup. There are tons of them out there. It is going to come with everything and designed to all work together.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #5 of 6 Old 09-19-2013, 01:23 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
PMF uses a hanger lift set up. u use your stock springs up to X amount of inches and then add lift springs to get X+ inches. Icon is said to have the better riding leaf spring for leaf pack lifts.
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #6 of 6 Old 09-20-2013, 07:51 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Icon IMO also has the best Hanger kit construction....
You will always get a better ride quality from a Hybrid hanger kit spring lift than from a spring only lift.
CT Performance, Inc. is offline
