8" dually lift - Ford Powerstroke Diesel Forum
post #1 of 20 Old 09-12-2013, 03:25 PM Thread Starter
BLACKDUALLY's Avatar
8" dually lift
Sorry if this thread is started somewhere I tried looking but there's 108 page to go through and I haven't seen what I'm looking for , I am looking to do a 8"bds lift with their upgrades with shocks and steering stabilizer, my question is do I defiantly need to modify my front drive shaft and who is a good company to go to in the Maryland area? and brake lines does modifying my brake hose brackets work or should I just get longer lines? and how's the drive comfort? I believe paying for the right s*** first versus fixing it later, besides interco who make a good 37/12.5/16 or 37/13.5/16, I'd love pic if anyone has any, dually or srw, thank you for everyone's help.
BLACKDUALLY is offline
post #2 of 20 Old 09-12-2013, 04:15 PM
JustinOOO9's Avatar
Quoted: 507 Post(s)
Garage
I'll post a pic tonight but:
2004 f350 SRW i had to get extended brake lines, and diffeent brake line brackets. my front driveline was barley long enough so i used it and never had issues... i ran a superlift with replacement springs front/rear and rode a little rough even with different shocks but it had like 8+leafs in each pack.
i removed it and went to a 4in though...
toyo mt
bfg
kumho make a 37 with 16 in wheel
8in superlift with 38x14.5R18 toyo mt's i miss it but the tires are $$$$
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is online now
post #3 of 20 Old 09-12-2013, 05:05 PM Thread Starter
toyo mt
bfg
thank you, truck looks awesome, did you buy or fab your brake line brackets? if you bought them where did you get them from, I want to have everything I need at once so I don't have to go s*** I need more parts or the truck be down.
post #4 of 20 Old 09-13-2013, 03:33 AM
JustinOOO9's Avatar
Quoted: 507 Post(s)
Garage
most if not all lift kits come with extended brake-line/ different mount brackets.
mine was an 8in superlift but i had it removed and got a 4in rough country kit it has the extended brakelines with it.
p.s. when your order a lift kit and items such as: pitman arm, carrier bearing drop bracket for rear drive line are just an option... you typically need it its a cheap way of getting extra cash from people for an 8in ift you will need the following:
front
-front leafs
drop pitman arm
-track bar relocation bracket and or adjustable track bar
-sway bar lowering bracket or extended front sway bar end links
-extended front brake-lines and most likely a new bracket
-ubolts
-possibly shims to get the pinion (part your drive line bolts up to) to make the angle on front drive line easier
-I did not need to get my front drive line extended but i only had like 3 inches of slip yoke travel so i recommend drive line extension shouldn't be more then $150 with new balancing
rear:
-replacement leafs, or block with oem leafs or add-a-leaf with oem leafs
-carrier-bearing drop bracket (it makes the 2 piece drive line line up with bigger lift kit)
-u bolts and hardware
-sway bar brackets or new end links
possibly extended brake lines i dont remember honestly
and usual shocks and misc hardware etc...
try and stick with:
zone, bds, fabtech, skyjacker, rough country, pro comp etc... most name brand lifts you can get complete and it will be most likely cheaper to ship to a business then your house
sorry for long post more experienced people chime in shortly...
bigger tires and wheels means possibly re-gearing front/rear difs and a upgraded brake pad/rotor will be good saftey measure
Justin,
post #5 of 20 Old 09-14-2013, 03:36 PM
2004 f350 8" All spring lift.
Extended brake lines were needed.
I needed to extend and balance front drive shaft.
Needed to shim the carrier on the rear drive shaft.
Depending on how you lift it a 8" leaf spring will ride alot rougher then a 4" lift spring. My truck rides pretty good for what it is.
You may want to contact Trevor at PMF or Cary about putting a kit together for you. Something like a 6" leaf spring with a hanger and shackle kit in the front, combined with a traction block and a 4" or 6" spring.
I disagree with the user above you will want a drop pitman arm to keep geometry correct and avoid bump steer.
I suggest Icon if you want a quality kit. BDS doesn't stand up to Icons quality.
2004 F350 PSD
8" Icon, Loud Pipe, 58v FICM, Deleted, MudGrapplers, Edge Insight, Sct tuned by Vivian.
2011 F350 PSD
AFE , Airbags, Recon, BMF , Nitto,
20046.0 is offline
post #6 of 20 Old 09-16-2013, 06:37 AM Thread Starter
[quote=BLACKDUALLY;6629025]
I suggest Icon if you want a quality kit. BDS doesn't stand up to Icons quality.[/
Thank you ill look into the pmf suspension, never looked into them before, hows the quality, fitment and ride of the pmf lifts?
Thankyou, never heard of pmf, just visited their web paged and they have some pretty sick looking suspension, hows the quality, fitment and ride, if anyone has a full suspent lift from pmf i'd like to heard their input too.
post #7 of 20 Old 09-16-2013, 09:18 AM
Quoted: 3 Post(s)
[quote=BLACKDUALLY;6629033]
Top notch, all of it. You'd be hard pressed to find anyone who wouldn't recommend his products
11 F250 CCSB King Ranch
Tyrant tunes, No Limit Stage 2, No Limit Block Off, 5" exhaust, CTS
2.5" Carli Commuter, 4.5" PMF block, 37x12.5R20 Toyo RTs, Stock wheels
01 Ex 7.3l Limited
Swamps tunes, 6637, 4" exhaust, 6.0 trans cooler, Hellwig rear swaybar, CTS
06 headlights
bigred3297 is offline
post #8 of 20 Old 09-16-2013, 12:11 PM
layson's Avatar
Quoted: 83 Post(s)
What year of truck is the kit going on?
I would probably go with an Icon either way. Talk to Marty at Truck Toyz performance in Texas. They can help you with exactly what you need to do to do it correctly....
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #9 of 20 Old 09-16-2013, 12:23 PM
Quoted: 3 Post(s)
Icon makes quality kits as well. I'm running their leaf springs and they're great
01 Ex 7.3l Limited
06 headlights
post #10 of 20 Old 09-16-2013, 12:37 PM
DunesRunner08's Avatar
there's garbage kits there's good kits and there's phenomenal kits.... of course the best kits are gonna cost the most... Icon, OUO, RIZE, Bulletproof, PMF, Kelderman, ETC are awesome kits... you get into fabtech, procomp, BDS, etc... they are good and with upgrades are very good... Zone is a cheap kit that is good quality... then you have Rough Country and Tuff Country and similar kits which are cheap Chinese made kits that ive seen parts break and geometry to be off so tire wear and other stuff goes on... not a fan of them... when dealing with automotive parts, that "little bit extra" money is always worth a lot in terms of quality.. just saying
Beware!!!! The King Has Returned
DunesRunner08 is offline
