what is the difference between 1999 and 2000-2004 - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-12-2013, 05:41 AM Thread Starter
I am looking at front end parts and wondering what parts are different on the 1999 and the 2000-2004? Mainly because I am thinking about buying a kit off a 99 and wondering what all I would have to change
PowerstrokeAaron is offline
post #2 of 4 Old 09-12-2013, 07:50 AM
Top Gun Customz is showing as many lifts being 99-04 as they are 00-04.
Top Gun Customz - Suspension Lifts
About the only real difference was that the early trucks had a crash bar (bolt on front cross member) that was deleted in later trucks. If you can't figure out the difference by reading the lift kit description, a call to a supplier should clear things up.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #3 of 4 Old 09-12-2013, 06:01 PM Thread Starter
thanks, called them and the early 99 pitman arm has different splines they said.
post #4 of 4 Old 09-13-2013, 07:10 AM
Quoted: 3 Post(s)
Yup, that's the only thing that makes one kit work and the other not. Everything else bolts up the same
11 F250 CCSB King Ranch
Gearhead tunes, No Limit Stage 2, No Limit Block Off, 5" exhaust, CTS
2.5" Carli Commuter, 37x12.5R20 Toyo RTs, Stock wheels
01 Ex 7.3l Limited
Swamps tunes, 6637, 4" exhaust, 6.0 trans cooler, Hellwig rear swaybar, CTS
06 headlights
bigred3297 is offline
