Need help! Questions on air lift - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-01-2013, 03:03 PM Thread Starter
HunterER7's Avatar
Exclamation Need help! Questions on air lift
Well I'm looking to lift my 02 7.3 crew cab long bed. I want to do an air lift capable of sitting on 40" tires no problem. My questions are where do I start? What's the best way to go about doing this and what companies should I look at?
I would like to hear any and all thoughts. Looking to collect and do as much homework as possible.
Thanks guys
HunterER7 is offline
post #2 of 6 Old 09-01-2013, 03:06 PM
ZMANN's Avatar
Quoted: 1596 Post(s)
very few companies sell a complete front rear setup and even fewer sell one worth owning
doing a DIY setup will put you into a money pit of a trial and error curve
have you looked at Kelderman
We Miss you Ronnie
ZMANN is offline
post #3 of 6 Old 09-01-2013, 04:11 PM Thread Starter
HunterER7's Avatar
Wasn't exactly looking to get a complete kit but it'd be nice. I just want the end result whether I piece one together or not.
Looked into kelderman but I've haven't found a price on the entire kit anywhere.
post #4 of 6 Old 09-01-2013, 04:26 PM
ZMANN's Avatar
IIRC a Kelderman is going to be 5k ish
they might Be a sponsor on here I know they are on one of these big 3 forums /Army/nation/Org
while it seems easy to get it up in the air with bags and links shock valving and bag type are key a few have mastered it so if they chime in you will be better off
We Miss you Ronnie
ZMANN is offline
post #5 of 6 Old 09-01-2013, 05:34 PM Thread Starter
HunterER7's Avatar
Thanks man I'm hoping someone who has done it will give me a heads up.
post #6 of 6 Old 09-09-2013, 09:33 AM
layson's Avatar
Quoted: 82 Post(s)
In my opinion I would run something different up front than an air bag. Air bag setups are very high maintenance. They are more for looks than function, several guys I know that have full air bag setups front and rear would have never bought another kit again after owning one. Just think of the steering with an air bag setup. You will only have one spot where the steering wheel is going to be straight. You lift it or lower it, it will rotate that steering wheel. I looked into these setups a while ago and learned it was not for me. In my opinion this would be a kit for a truck that drives onto a trailer and heads to the truck show, then comes off the trailer for the show. It isn't a daily driver.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
