Leveling Kit for a F-550 - Ford Powerstroke Diesel Forum
post #1 of 12 Old 08-31-2013, 07:10 PM Thread Starter
5fifty's Avatar
Looking to get a leveling kit for my 550.
Found the Readylift 2.5 inch kit with drop bracket for track bar.
What else would I need? Are alignment cams needed?
At what point do you need to install drop brackets for the radius arms?
Having trouble finding suspension lift parts for the 2005 to 2007 F550. More support for the newer models and the older leaf spring model s.
2005 F-550 4x4 22.5's
Kelderman Air Ride
Bulletproof Diesel Remote Oil Cooler W/F550 Cooler
Bulletproof Diesel Billet Water Pump
Bulletproof Diesel Radiator
Dieselsite Wicked Wheel, Dieselsite Coolant Filter Kit
Warren Diesel 155/30, Bluespring Mod, 6.4 Banjo,
Updated STC, Turbo Feed and Drain Tubes,
PMM EGR Delete
SCT Tuner, Edge Insight w/EGT, Fuel and Oil Pressure
Tuned By MATT @ Gearhead Automotive Performance
5fifty is offline
post #2 of 12 Old 08-31-2013, 07:20 PM Thread Starter
5fifty's Avatar
Also open to other suggestions of parts that I could put together to get me around 2.5 to 3 inches of lift. I have read that some have used parts from F350 lifts to make up something for the 450-550's.
TIA
Kelderman Air Ride
PMM EGR Delete
5fifty is offline
post #3 of 12 Old 08-31-2013, 07:54 PM
Quoted: 51 Post(s)
I used the 7K LB F550 coils to level my F250. I recall they come standard on the LWB cab and chasis models only. About $99/ea from Ford. Not sure what you have in place now, but worth a look.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDC Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #4 of 12 Old 08-31-2013, 08:02 PM Thread Starter
5fifty's Avatar
Not sure which coils are in it now. I got the truck used. It seems to sit a little lower than other 550 4x4s
I have seen some 7k coils listed for sale here and there.
Did you do anything with the track bar and need any cams for the alignment?
Kelderman Air Ride
PMM EGR Delete
5fifty is offline
post #5 of 12 Old 09-01-2013, 05:54 AM
Quoted: 51 Post(s)
I did. I did the Icon alignment cams as well as the Icon adjustable track bar. If I recall correctly, for each inch of front lift, the front axle shifts 1/4 to 1/2 inch toward the drivers side.
Best place for the 7K coils is from Ford. Part #: 5c3z-5310-AA Takes about an hour to change both. You will also need longer front shocks.
Icon 2.5 CDC Shocks
Carli Track Bar
Previous:
All the BPD goodies
skanj0 is offline
post #6 of 12 Old 09-01-2013, 06:33 AM Thread Starter
5fifty's Avatar
Thanks for the info. I have looked at the Icon parts and have searched the net as much as possible. I dont mind piecing parts together to get where I need to be.
I have found the Bilstien shocks too.
As for the axle moving forward, I cant have to much of that cause I am trying to squeeze 255/70r22.5's in there...LoL What can I do to keep it from moving forward with under 4 in of lift?
Kelderman Air Ride
PMM EGR Delete
5fifty is offline
post #7 of 12 Old 09-01-2013, 07:22 AM
Quoted: 51 Post(s)
Sorry, the axle doesnt move forward, it moves sideways toward the drivers side (since the track bar is anchored to the frame near the drivers side, the higher the truck goes above the axle the more the axle shifts toward the drivers side). If anything, the axle will move backward a tad, since the radius arms are fixed where they attach to the frame, so the higher you lift the truck the more the axle "rotates" and moves rearward. Radius arm drop brackets make this better, but a 3 or 4 link setup solves this issue and also allows for much better front end alignment without the need for caster cams. Check out the kits that Trevor (PMF) offers: Welcome to Precision Metal Fabrication - USA Built suspension systems
Icon 2.5 CDC Shocks
Carli Track Bar
Previous:
All the BPD goodies
skanj0 is offline
post #8 of 12 Old 09-01-2013, 12:51 PM Thread Starter
5fifty's Avatar
Thanks for clearing that up. I looked at the PMF site and will be contacting them. I see that they have drop brackets for 3". SO I should be able to get an adjustable track bar, coils or spacers, and the brackets for the sway bar as well as shocks etc and hopefully get me where I need to be.
I haul a good amount of the time so I need this to be right.
I found a stock 550 setup like mine that I am going to measure for a height reference to compare.
I dont want to go much higher than 3" in lift cause I am already going to get 3" of lift out of the tires alone. Get to be a PITA climbing in and out after a long day.
Kelderman Air Ride
PMM EGR Delete
5fifty is offline
post #9 of 12 Old 09-01-2013, 03:35 PM
Quoted: 51 Post(s)
I don't want to go much higher than 3" in lift cause I am already going to get 3" of lift out of the tires alone. Get to be a PITA climbing in and out after a long day.
Sounds like you will have a sweet ride!
Definitely give Trevor at PMF a call. His customer service is outstanding. A few weeks ago I ordered a set of his 3/4" diameter u-bolts and custom spring plates, at 4:30 pm PT on a Friday. An hour later I received a UPS tracking number! I thanked Trevor for the quick shipment, and he casually mentions that he had a few spare minutes at the end of the day (remember I placed a web order at 4:30PM PT), so he bent me up some custom U-bolts and got them to Fed-Ex - late on a Friday.
Icon 2.5 CDC Shocks
Carli Track Bar
Previous:
All the BPD goodies
skanj0 is offline
post #10 of 12 Old 09-01-2013, 03:44 PM Thread Starter
5fifty's Avatar
Thanks, I have been wanting to do this for a while now and been gather info and funds to do it.
I like to hear about companies with awesome customer service. Sounds like someone I need to talk to. From what I can see they probably have what I need or can make it.
BTW, when you get a chance can you count how many coils are on your 7K coil? There are 10 on mine just trying to see what the difference might be.
Thanks
Kelderman Air Ride
PMM EGR Delete
5fifty is offline
