06 f250 PS 6inch lift and leveling Kit??? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-31-2013, 03:55 PM Thread Starter
Quoted: 2 Post(s)
I got the 6inch rough country lift. I need get few more inchs out the front could I throw a two inch leveling Kit up front on top 6inch an I got a 3inch block on top of factory 2inch so 5 in total in the rear was thinking pull the 2inch out put a three so be total of 6 in the rear... This something you can do or not safe to ride on please let me no.
89ezgo is offline
post #2 of 6 Old 08-31-2013, 04:22 PM
TheFordman87's Avatar
Add a leaf pack in the front works great. You will probably need to get new U bolts made for the front bringing it that much higher. But that back i reccomend you try to get a single 6 inch block. But if not and you decide to put a 3 in h block in place of the 2 inch it should be fine.
Zone Offroad F4 2.5" Leveling Kit Fits 99-04 Ford Super Duty
I recommend one like this ^^^^^
I'm addicted to diesel and I step on it constantly!
TheFordman87 is offline
post #3 of 6 Old 08-31-2013, 05:36 PM Thread Starter
Quoted: 2 Post(s)
My front coil not leaf
89ezgo is offline
post #4 of 6 Old 09-03-2013, 02:41 PM
Yeah sorry i just seen that but you can use the circle block leveling kit it will work
post #5 of 6 Old 09-04-2013, 06:33 PM
In case you missed it in the last thread about wanting to run 40s.
Originally Posted by Karls03 View Post
8 inches is good to run 38s. Unless you intend to have a concrete four wheeler, you're going to need at least a 10 inch lift to clear 40s. Also, putting a set of 2" spacers will induce negative caster resulting in poor steering. Then you're spending money to correct that issue.
Sometimes the best thing to do with a good deal is to walk away.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #6 of 6 Old 09-04-2013, 07:27 PM
897.3alltheway!'s Avatar
Quoted: 13 Post(s)
not sure about the front but the rear either get a 6" block or if you stack them weld them together
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
