Carli, Icon or other. Leveling kit. - Ford Powerstroke Diesel Forum
post #1 of 22 Old 08-31-2013, 09:26 AM Thread Starter
2011 F350 4X4 6.7.
Looking to level it 2.5" was going to go with new coils, adjustable trac bar, front shocks, alignment cams. Now I work in the oilfield lots of gravel roads, pitted and rutted up locations. Looking for the best possible ride without changing the rear. It currently has air bags also.
2004 F350 PSD
8" Icon, Loud Pipe, 58v FICM, Deleted, MudGrapplers, Edge Insight, Sct tuned by Vivian.
2011 F350 PSD
AFE , Airbags, Recon, BMF , Nitto,
20046.0 is offline
post #2 of 22 Old 08-31-2013, 01:51 PM
I've got an 09', 4.5" lift with Carli's 2.5 system on 37's. I love it! way better than stock on the street, in the dirt it's awesome. I know a lot of r&d went into their 2.5" leveling system, give them a call, or read some of the forums here. good luck bud
See you in the Dirt!
76hauler is offline
post #3 of 22 Old 08-31-2013, 01:55 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
I work in the patch myself so I know what your driving in. We ended up running stock with air bags. Worked out awesome so far and most trucks get a nice lift in the front as well.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 22 Old 09-01-2013, 12:16 PM Thread Starter
I guess I should be asking how the Coil springs differ from each other. Which ride softer?
2004 F350 PSD
2011 F350 PSD
20046.0 is offline
post #5 of 22 Old 09-02-2013, 09:00 AM
cumminchevy's Avatar
I have the 4.5" pintop system. Full deavers in the rear. I'm in the patch as well. It would be hard to beat.
Sent from AutoGuide.com App
2012 F350 PSD Lariat FX4 CC single wheel. 5" stainless MBRP dpf back. Carli pintop w/ full deavers, long travel air bags, high mount stabilizer, Walker Evans street wheels 17x8.5s w/5.5 bs and 37x13.5 Toyo Open Country MTs
cumminchevy is offline
post #6 of 22 Old 09-02-2013, 08:54 PM
layson's Avatar
Quoted: 82 Post(s)
Go with the icon
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #7 of 22 Old 09-02-2013, 09:41 PM
Black2011SD's Avatar
Carli 2.5 pintop 2.5" leveling kit.
Black2011SD is offline
post #8 of 22 Old 09-03-2013, 04:50 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
If you want the best ride quality you need to replace the factory radius arms..second best improvement is shocks..larger the body the better the ride quality can be.
I would look at a Pure Performance max travel or same with 4 link arms.
PM me if I can get you more info.
Cary
CT Performance, Inc. is offline
post #9 of 22 Old 09-03-2013, 08:59 AM
OCVeloMan's Avatar
Quoted: 173 Post(s)
Garage
All things held constant, the difference in ride quality between a radius arm and a 4-Link is negligible.
OCVeloMan is offline
post #10 of 22 Old 09-03-2013, 09:02 AM
Quoted: 3 Post(s)
In your opinion....could have something to do with you not having them..
