6in lift rear end swaying - Ford Powerstroke Diesel Forum
post #1 of 12 Old 08-31-2013, 07:46 AM Thread Starter
So i put a 6inch BDS lift on my truck around February. About a month ago i noticed the steering being very sloppy. After taking it back and fourth to a mechanic and by the end of it having a new pitman arm put in, and a new steering box put in, the steering is now nice and tight like its brand new.
But i noticed at higher speeds and by moving the wheel back and fourth, the rear end seems to sway a lot and be all over the place. Its actually pretty scary driving on the highway. So i decided to take it to a professional off road shop near me to have him look at it. He took it for a ride and said thats perfectly normal. He said the reason i started feeling it now and not when i first put it in is because the rear springs must have finally broken in. But all in all he said with big lifted trucks thats what they do and its not bad at all.
So thats where im at now. But for some reason i just feel like this cant be right. I feel like if it were there would be a lot less lifted trucks around here cause no one would want to deal with it. Especially if they take it on the highway. So basically im looking for some input from you guys. I wanna know if he in fact is right and its something i have to get used to and change my driving habits around or if there's a way to tighten it up. Thanks for any help guys!
2007 F-250 Lariat Outlaw 6.0L CC SB
5'' Turbo Back MBRP Exhaust to 7" stacks
CAT & Muffler deleted
Edge Insight CTS
Sinister Diesel Coolant Filter
Glow Shift EGT Gauge
Blue Spring Upgrade
PHP Atlas 80 FICM Tune
Bulletproof Diesel 48V FICM
EGR Deleted
Updated Standpipes and Dummy Plugs
6'' BDS Radius Arm lift
37'' Toyo M/Ts on 18'' XD Monsters
xford250x is offline
post #2 of 12 Old 08-31-2013, 08:17 AM
ZMANN's Avatar
Quoted: 1664 Post(s)
I suggest
checking the shocks and make sure they are doing their job
I didn't have a lot od sway with a 6 nor an 8 inch lift be it all spring or block
I however have added air bags and a rear sway bar ( front was oem) to improve towing and cornering
We Miss you Ronnie
ZMANN is online now
post #3 of 12 Old 09-03-2013, 05:18 PM
Brossjd's Avatar
I feel your frustration.
I also installed a 6Ē BDS radius arm drop lift kit with replacement rear leaf springs. I installed the kit a little less than a year ago on my then brand new 2012 F250. I have not been happy with the steering and rear end wagging just like you. My truck now has rather poor steering when centered. It takes about 2Ē of steering input just to stay in my lane. Also I have the rear end wagging feeling as you explained. I tell people itís like landing a small plane in a cross wind. If I give the steering a wiggle back and forth, the truck feels like itís just leaning over and then yawing, but not steering and changing direction. I have not solved any of my problems either. I have been thinking the steering gear box could have some problem but it is brand new.
I agree with you 100%, if every lifted truck drove as loose, and squirmy as our trucks, I canít imagine there would be so many out there. I have been moments away from putting the truck back to stock, but then I figure there must be a solution so I stick it out hoping I will find something wrong. Don't get me wrong I don't blame BDS at all. I believe thier kit is very good.
Here are the steps Iíve completed trying to solve the issue and the amount of success each produced.
- I replaced the caster/camber alignment cams provided by BDS with a pair that had the most caster I could find. BDS provides 2.3/.6 cams and I found some 2.5/.3. They provide just a bit more caster and a bit less camber. This did help some of my straight line wandering and provide a bit better self centering, but only very marginally.
- I was told by my local 4X4 shop to retighten the rear axle u-bolts again. He said things will settle in and the bolts will need re-torquing a few times. This has been the best advice so far. The first time I checked the torque they definitely needed two or more rounds to make the torque spec. This did help the rear end wag feeling the most.
- I installed an aftermarket solid tubing steering link, equipped with the problem solver ball joint at the pitman arm. I was told the stock link had a tendency to flex and provide play. This made no improvement at all.
- Iím not sure what tires you have, but I was also told about tread squirm. I have 37x12.5X18 Proc Comp Extreme AT. These have rather large tall tread blocks. I have been told these tires can also move around at speed and make the truck feel like its floating. We will see as they wear down if that improves. Also we have to keep them aired up rather high to satisfy the TPMS. I think they may feel better if we could air them down a bit.
- I have been searching long and hard for a longer pitman arm to speed up my steering and help eliminate the play. Not many people have a ton of options for the '11, '12, 13 super duty.
Good luck. I hope we can both improve our trucks handling.
Brossjd is offline
post #4 of 12 Old 09-03-2013, 06:44 PM Thread Starter
Thanks for the reply man..
Lately I've been thinking about maybe getting a sway bar for the rear end, maybe thatll help stiffen it up a bit. Was also wondering if maybe traction bars would make a difference since i currently dont have any.
As for tires I have 37x13.5x18 Toyo MT. Ive heard they can be a bit rough and tend to pull a bit. But it still shouldnt be that bad in the rear.
Ill have to re check the torques on the nuts in the back, maybe thatll help too..
But all I know is im left scratching my head, and its annoying because it just doesnt feel safe to drive on the highway. Which I am planning on taking a few trips out of state in the near future.
But good luck to you too and thanks for the help!
Edge Insight CTS
Blue Spring Upgrade
EGR Deleted
post #5 of 12 Old 05-01-2014, 04:40 AM
Power$troke's Avatar
Quoted: 2 Post(s)
Garage
I know its an old thread but I found out the issue with the swaying is caused by the track bar and steering linkage not being parallel with each other. I had the same issue and went through the same steps. I found a shop that specializes in alignments on lifted trucks and once the truck was up on the lift he showed me how the front axle would move side to side (slightly) as the steering went back and forth. I also have some bump steering as a result of this. So the front axle moves abit which cause the truck to have that sway. Sorry for the late reply but hope this may help others.
2006 6.0 SD Crew Cab Lariat "Bullet Proofed"
8 inch Kit
Dual Steering Stabilizers
Adjustable Trac bar
37" Trail Grapplers
20X12 Armour Rims
ARP Studs
SCT X3
XDP EGR Delete
Edge Evolution
BPD FICM
PM Coolant filter
MBRP 4in Exhaust
Blue Spring Mod
High Idle Mod
HID 6k headlights / 23" LED Light bar 9000 lumens
Rock LED Lights in each fender well
Oracle LED wheel Rings (White LEDS Only)
LED BED Lights
Horn Blaster Horns
200psi 13 gallon on board Air system
Power$troke is offline
post #6 of 12 Old 05-03-2014, 07:16 AM
scummins's Avatar
I have a zone 6" lift, a bds spinoff. It drives straight and true. The only thing I wasn't happy with was the stiffness of the springs and add a leafs. Also the shocks are garbage.
I'm thinking it's really something not right in your front end' like the previous poster said.
11 Lariat
6" lift, 37's, Moto Metals, H&S, SPE, JL SPL2K
scummins is offline
post #7 of 12 Old 05-09-2014, 03:00 AM
I have a 6" lift and rear sway bar. Plus 4 35"s on the back. My truck is tight on the highway even at 80mph.
zpi28 is offline
post #8 of 12 Old 05-09-2014, 08:26 PM
897.3alltheway!'s Avatar
Quoted: 13 Post(s)
6" with no rear sway bar on my 89 , even with a car on top i go 80 down the freeway just fine
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
post #9 of 12 Old 05-09-2014, 08:34 PM
ZMANN's Avatar
you don't count
We Miss you Ronnie
ZMANN is online now
post #10 of 12 Old 05-10-2014, 06:52 PM
I have a 4" BDS lift on a Brand New 2014. I get the sway mainly when I am towing 5000+ lbs on the bumper hitch. it's a little squirmy, and getting an alignment from a Firestone store helped general driving A LOT.
My buddy experienced the sway today when we bough a new 28' race trailer and it scared him. he's very used to trailers and towing. he was like WTF... I just said "I told You".
I plan on testing the tires, but will be checking the ubolts, not sure how to check the steering stuff.
EDIT: I just looked at my steering and they are not parallel for sure. To me that's a BDS issue since they designed the lift, and arm. I don't see anyway to really adjust that, so what is the fix??
Rap_Rider is offline
