How to get a smoothg riding F250/350 - Ford Powerstroke Diesel Forum
post #1 of 13 Old 08-30-2013, 03:25 PM Thread Starter
Fill it up again Dummy
mhatlen's Avatar
Quoted: 484 Post(s)
Garage
I have recently done a suspension modification to my trucks rear spring pack.
I cut out a plate from 3/8 steel the same size as the factory shim for the spring packs. I placed it above the overload spring and at the same time extended the spring alignment tabs another 1/2 so it will still keep the springs from walking around sideways.
I have taken some pictures of the work to show how it was done.
Attachment 161609
Attachment 161617
Attachment 161625
Attachment 161633
The ride is great I have been driving it this way for a few weeks now and love it. It no longer gallops down the highway and the ride quality is hard to believe.
I know the rear will sag much sooner with less weight but I am not concerned because it rode the bumpers when it was full of firewood before.
Ride is better than my wife's 2002 Tahoe.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
post #2 of 13 Old 08-30-2013, 03:53 PM
banshee-rider's Avatar
Quoted: 7 Post(s)
Garage
Did you lose any rear ride height?
2005 FORD F250 CREWCAB LARIAT
9 INCH LIFT
37x13.50x20 TOYO M/T'S
PMF TRACTION BLOCKS AND BARS
MBRP 4 INCH TURBO BACK
ARP'S,STAND PIPE'S, DUMMY PLUGS ALL THE UPDATES
SCT LIVEWIRE SRLxx
2008 SUPERDUTY TAILLIGHTS
OPT7 LED HEADLIGHTS AND FOG'S, 50 INCH LED BAR
AMP RESEARCH POWER STEP'S
AIR BAG'S TRAIN HORNS AND AIR COMPRESSOR
CUSTOM STEREO
XDP COOLANT FILTER
PSC HYDRAULIC ASSIST STEERING
RCD EGR DELETE
EXCURSION CENTER CONSOLE
2007 REAR VIEW MIRROR AND MIRROR SWITCH UPGRADE
banshee-rider is offline
post #3 of 13 Old 08-30-2013, 09:26 PM
79 toy's Avatar
Looks like stacked blocks?
79 toy is offline
post #4 of 13 Old 08-30-2013, 10:01 PM
BIG Laing's Avatar
This dropped your payload capacity severely.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #5 of 13 Old 08-31-2013, 05:18 AM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
Nice idea. If you wanted to increase your payload capacity again, you can install a set of air bags.
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #6 of 13 Old 08-31-2013, 05:47 AM
Term3's Avatar
Quoted: 2 Post(s)
So basically all you did was remove a leaf from your springs because that spacer is basically making the bottom leaf pretty much useless. Couple issues. First - there is no longer any support for the spring pack so there is nothing protecting it from being forced into a reverse curve which is not good because by the time the upper leafs contact that lower leaf its too late. Second - now that you have a softer suspension your making your truck handle worse. If you want a better riding and a safe riding safe truck I would talk to someone that really knows suspensions like Cary at CT Performance Inc who is a supporting vender and does wonders with making Excursions ride 100% better.
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #7 of 13 Old 08-31-2013, 12:40 PM Thread Starter
mhatlen's Avatar
Quoted: 484 Post(s)
Garage
When I load the truck heavy with firewood it rides the bumpers tight. It will not go any lower then the bumpers for max travel.
Yes the load capacity is lower but it hits the overload at 2-1/2" of travel and starts taking the load from there till the bumpers.
I run empty 99% of the time so for me it's pure bliss and the bumper will only allow the maximum designed deflection.
That hunka chunka of overload spring is determining the ride in the rear. No shocks of any design can overcome it's values. A completely different spring pack is another story.
Not for everyone but for my empty truck it's awesome.
7" Icon/Carli Lift
Atlas40
mhatlen is offline
post #8 of 13 Old 11-14-2013, 07:05 PM Thread Starter
mhatlen's Avatar
Quoted: 484 Post(s)
Garage
Here you go I threw it back on page one.
7" Icon/Carli Lift
Atlas40
mhatlen is offline
post #9 of 13 Old 11-14-2013, 07:20 PM Thread Starter
mhatlen's Avatar
Quoted: 484 Post(s)
Garage
It does not drop the payload, I loaded truck with oak firewood two weekends ago and it settled faster but once spring pack hit the overload it loaded out the same. It never hit the bumpers so I know it's the same as before.
This mod works, only real downside I see is truck settles faster with moderate load. But once I get around a thousand pounds it's into the overload and loads out the same.
Cheers
7" Icon/Carli Lift
Atlas40
mhatlen is offline
post #10 of 13 Old 11-14-2013, 08:10 PM
BIG Laing's Avatar
It did drop the payload. Looking at a the leaf pack you now only contact the overload on the furthest edges (least strength). It should be contacting the entire length of the overload. Really its very simple leverage/physics.
