replacing castor bushings...... - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-28-2013, 01:12 PM Thread Starter
How difficult is it to replace the factory castor bushings with the Carli or Icon bushings? I'm considering a 2-1/2" Carli or Icon leveling kit on my 2013 Super Duty 6.7. I don't think the install will be that tough except for the bushing change. I've installed several lifts on Toyotas but I've never attempted any ball joint work on a Ford. My truck has only 500 miles so nothing should be seized or rusted. Suggestions, help and advice appreciated.
highmileage is offline
post #2 of 4 Old 08-29-2013, 07:35 AM
OCVeloMan's Avatar
Quoted: 179 Post(s)
Garage
Easy....
1 - Jack truck up and support axle with jack stands.
2 - Remove wheel and tire.
3 - Remove cotter pin and upper ball joint retaining nut
4 - Remove the factory sleeve sandwiched between the knuckle and the ball joint.
5 - Install adjusted caster sleeve onto ball joint ensuring proper orientation. (usually thicker side to the front).
6 - Hold the adjustment collar with a wrench while torquing the ball joint nut to factory spec ensuring the adjustment shim orientation remains the same (doesn't twist).
7 - Install new cotter pin
8 - Install wheel and tire and repeat on the other side.
OCVeloMan is offline
post #3 of 4 Old 08-29-2013, 09:11 AM
Skyd Ram's Avatar
Quoted: 149 Post(s)
Originally Posted by OCVeloMan View Post
Easy....
It's even easier to toss them at the alignment tech and have them put them in when you take the truck in for the alignment.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is offline
post #4 of 4 Old 08-29-2013, 12:12 PM Thread Starter
Thanks guys !!
