Cheap & Safe Suspension Lift - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-26-2013, 06:09 PM Thread Starter
I have an 03' F250 and I want to lift it a few inches to maybe get 35's on it. What would be the cheapest and safest way to do this?
Thanks
2003 F250 Super Crew - Sinister EGR Delete, ARP Studs, Blue Spring, FICM by Ed, Atlas 40, Pioneer Double-Din
1999 Dodge Dakota Sport 4x4 - Show Truck
2005 Scion XB - DD
jimdman is offline
post #2 of 9 Old 08-27-2013, 06:26 AM
305f250's Avatar
buy a used kit.
305f250 is offline
post #3 of 9 Old 08-27-2013, 01:57 PM
Maybe an extended Hanger in the front. Or some higher rated code springs.
2004 F350 PSD
8" Icon, Loud Pipe, 58v FICM, Deleted, MudGrapplers, Edge Insight, Sct tuned by Vivian.
2011 F350 PSD
AFE , Airbags, Recon, BMF , Nitto,
20046.0 is offline
post #4 of 9 Old 08-27-2013, 03:25 PM
codyryan07's Avatar
Thanks
I'd go with a 2" lift shackle and an adjustable track bar.
Cody Ryan
03 f250 ccsb fx4 7.3
4" RC lift
35x12.50 federals on 20x12 rockstars
6637 intake, straight pipe
full RR w/ fuel bowl delete.
rebuild coming soon
codyryan07 is offline
post #5 of 9 Old 08-28-2013, 10:56 AM
An extended front hanger will induce negative caster resulting in handling issues. A longer shackle will increase positive caster without the handling issues.
I would say either higher rate springs or a no kidding 2" lift spring. I have run a 2" front lift with the OEM track bar and it was fine. Over that, you really need to look into a dropped pitman arm and drop bracket for the track bar.
Just an example of what's out there.
http://www.topguncustomz.com/p-2597-...-duty-4x4.aspx
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #6 of 9 Old 08-28-2013, 12:19 PM
79 toy's Avatar
http://www.roughcountry.com/images_large/ford_511.jpg
What would this do to its handling ?
79 toy is offline
post #7 of 9 Old 08-28-2013, 01:00 PM
It will make your truck a little taller in the front. OK, that was sarcasm for for not a whole lot will change in handling. Except for the fact it will be taller up front. Lowering front and rear mounts maintains proper caster. Speaking of caster, excessive positive is ALWAYS better than negative.
I ran a small lift on the front of mine for a while, I didn't change shocks, sway bar links, or anything else until I went to my 5 inch lift.
Karls03 is offline
post #8 of 9 Old 08-28-2013, 03:25 PM
79 toy's Avatar
Sweet thanks for the info in wanting to do 2" hanger kit on the front and f350 block on the rear.
79 toy is offline
post #9 of 9 Old 08-28-2013, 06:45 PM Thread Starter
Has anyone ever had issues with the mini spring packs. I also tow around 8000 lbs.
2005 Scion XB - DD
jimdman is offline
