Cutting springs - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-24-2013, 09:39 PM Thread Starter
strokethis04's Avatar
Quoted: 3 Post(s)
Cutting springs
Has anyone or could you cut front springs? I want to level my 08 f-350 and a buddy has a set of 6 inch lift coil spring out of his f-350. I don't really like the look of spacers
Sent from AutoGuide.com App
2004 f-350 cc 6.0l
afe stage 2
4in magnaflow
sct with looney from dj
6 inch lift
33x15.5 mt atz
16x10 raceline renegads
zoodad
auto meter gauges
strokethis04 is offline
post #2 of 7 Old 08-24-2013, 09:52 PM
BIG Laing's Avatar
Sell the 6" coils and get these Ford Super Duty Leveling Coil Springs for a 2.5" Suspension Lift for only $315.
I have seen coils cut down to lower a vehicle, never thought it was a good idea.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #3 of 7 Old 08-24-2013, 10:45 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
If you cut down the 6" springs, they will give you a much stiffer ride than using the correct ones!!!
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #4 of 7 Old 08-25-2013, 02:20 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
That is correct, you can no doubt cut them but the spring rate is calculated with the whole spring intact. A taller spring is going to give you more suspension travel and if it's a quality spring a better ride too.
I would also lean towards all spring and no spacer..
You can give those springs a try and see how they do It's a easy job that takes all of 30 minute to complete.
I have I-Con progressive coils on my 06 and they are a 7" lift and the ride is better than it was with stock springs. They have 2-1/2 and 4" as well.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
post #5 of 7 Old 08-25-2013, 03:43 AM Thread Starter
Quoted: 3 Post(s)
Ya I never really thought of it making it a rougher ride. I think I will wait and do it the right way. Thanks for the help
2004 f-350 cc 6.0l
afe stage 2
4in magnaflow
6 inch lift
33x15.5 mt atz
zoodad
auto meter gauges
post #6 of 7 Old 08-26-2013, 07:24 AM
Pure Perf's Avatar
Cutting the coils like mentioned above will increase the spring rate dramatically. It is not like you are cutting a part of a winding, you are cutting a significant amount of the coil out of there! Not to mention, the Super Duty coils are very specific when it comes to end codes for proper fitment. If you cut one of the ends off it will probably bow like a mother and not sit in the spring seats right.
We offer some of the smoothest riding coils for leveling the super duties. Our 2.5's are progressive and ride as smooth as butter.
F250 Progressive Rate Front Coil Springs
Good luck with your build..
JP
www.pure-performance.biz
Pure Perf is offline
post #7 of 7 Old 08-26-2013, 07:47 PM
I cut a ring and a half off my procomp 6" coils, lowered it 2". I did not notice any differance in ride, have 15k miles on em no issues. It may techanically change the rate, but my but cant feel it. Mine were not progressive rate. I would not cut those. Gb
2006 F350 lariat 4x4, S&b intake, 4" exhaust, 03 turbo, sinister egr cooler, BPD remote oil cooler, BPD FICM, stc and dummys, diablowsport program, 5" lift, 35's, led fog bar, flatbed welding rig. SOLD. Went the darkside, 2014 ram 3500 daully.
gblauf is offline
