Leveling kit ? - Ford Powerstroke Diesel Forum
post #1 of 21 Old 08-24-2013, 05:04 PM Thread Starter
Leveling kit ?
Im looking at putting 35's on and I was checking out ebay for some leveling kits. I came across this and was wondering if anyone had any experience with this style. It doesnt sit on top of the spring like most Iv seen and looks pretty easy to install with no spring compressor needed.
Ford F250 F350 Super Duty 4WD Front Leveling Lift KIT 2005 2014 Ford 2 5" | eBay
06 F350 KR / 12 sprinter 323bhs
tomsws6 is offline
post #2 of 21 Old 08-24-2013, 05:10 PM
ngaraiderman's Avatar
Haven't seen that one before but I just ordered it. I figured its worth $20 to see. I will post some before and after pics when i get them
ngaraiderman is offline
post #3 of 21 Old 08-24-2013, 06:39 PM Thread Starter
Yeah, thats what I was thinking. Let me know how it goes. I think im going to order them anyway.
tomsws6 is offline
post #4 of 21 Old 08-24-2013, 07:04 PM
BIG Laing's Avatar
remember, you get what you pay for. This "Kit" doesn't even have A adjustable track bar or new shocks.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #5 of 21 Old 08-24-2013, 07:13 PM
Yes we known Lang. Lol. But not going to spend 2k for a leveling kit or lift as you suggested in the other leveling kit threads. This is only $20. And it does say you can order the adjustable track bar if desired. I believe it is worth $20 to see how it goes. I know many guys that run similar setups And have had the same good results as the guys that pay big money for a 2.5" leveling kit. And I also know several guys that have had bad luck with cheap kits and expensive kits also. If it doesn't work out then its only $20.
Guess we will see. Should be here later in the week and will be installed next weekend.
post #6 of 21 Old 08-24-2013, 08:19 PM Thread Starter
I really dont need new shocks as iv only got 40k on the clock but school me on the "adjustable track bar"
tomsws6 is offline
post #7 of 21 Old 08-24-2013, 10:00 PM
BIG Laing's Avatar
Your stock track bar, is what centers your front axle underneath your truck. When you lift your truck without replacing the track bar, the entire axle gets pulled 3/4" to the side. So if you look straight down the front of the truck, one wheel sticks out 1.5" further out then the other wheel.
So getting an adjustable track bar allows you to get everything in the right place. I suggest new shocks that are made for a 2.5" lift still.
post #8 of 21 Old 08-25-2013, 08:43 PM
^biglaing is exactly right. If you don't get the adjustable track bar it will hurt in the long run. I also order it from the same place.
Good info laing
post #9 of 21 Old 08-25-2013, 09:43 PM
Black2011SD's Avatar
Don't forget about caster adjustment. You will/should need new caster shims to get you back to where you need to be. Like somebody already said, the adjustable track bar is a must as well.
Black2011SD is offline
post #10 of 21 Old 08-25-2013, 10:01 PM
Jack Lester's Avatar
Quoted: 3 Post(s)
I went with the track bar drop bracket from Pro Comp it seemed to work ok...
Jack Lester is offline
