Is my Logic Correct?....Probably Not - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-23-2013, 09:57 AM Thread Starter
dbrandone's Avatar
Sorry in advance for the long post, I am new to diesels and truck suspensions so bear with me.....
I have an 05 F350 CCLB w/ 6in "Custom Lift". I bought the truck with the lift already on it and now want to upgrade some of the suspension components. The things I do know about the lift is that I have dual bilstein 5100 up front and the rear suspension is lifted with blocks. My Coil spring up front has a Ready Lift leveling kit spacer on top so my thoughts are that maybe the coil spring is made for a 4 or 5 inch lift and the leveling spacer lifted it up to 6 inchs but I may be wrong. I want to replace the coil spring with a 6 inch lift coil spring(maybe pro comp or the skyjacker soft ride) because I'm trying to achieve a softer ride and want to get rid of the leveling spacer. Is my thoughts correct that removing the leveling spacer will improve ride comfort?(Ive heard that leveling spacers can have a harsh ride)
For the rear, I want to take out the blocks and the current leafs and put in a set of 6 inch lift leaf springs instead of having lift blocks. To top it off, I wanted to upgrade the 5100's to 5160's all the way around.
Now, when i see complete lift kits they say something like 8in front/5.5in rear. Since I'm replacing the leafs, Should I get 6 inch lift leafs or will i need a different size since I want the truck to be level with the front?
2005 F-350 Lariat CC SRW LB FX4 - SIlver
Custom 6" Lift w/ Dual Bilsteins, 35/12.50/20 Nitto Trail Grapplers, 20x10 XD Strike Wheels in Matte Black, ARP Headstuds, PHP Gryphon FICM Programmer(Currently using Atlas 80), Volant Intake, 4" Turbo-back Straight Pipe Exhaust w/ 6in Tip, 6000k Retro Solutions 55w HID Kit
dbrandone is offline
post #2 of 5 Old 08-23-2013, 10:31 AM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
If you get rid of the front spacers and switch to a taller spring it should improve your ride.
Lift kits that show 8"front/5-1/2"rear are taking into account that the truck sits higher in the rear from the factory, so their lift kit will also level the truck.
If you are going with 6" front springs, then for the rear (if you are getting rid of your blocks) you do want to go with 6" lift springs to match the front.
Here is a pic of my 5" rear springs that match my 5" front lift:
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #3 of 5 Old 08-23-2013, 11:36 AM Thread Starter
dbrandone's Avatar
Thanks for the info. Exactly what I needed to know.
Would you recommend any leaf or coil springs for what i want?
The only leafs that Ive seen so far have been the skyjacker soft ride leafs, but I haven't looked overly hard. As far as the springs I've seen pro comp and skyjacker but dont have any info on those two springs to know if they would be good with my set up
post #4 of 5 Old 08-23-2013, 01:44 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
Keep looking, there are quite a few choices out there.
One choice is Ford - 2005 - 2007 Super Duty - Individual Components & Accessories - ICON Vehicle Dynamics
They have a good reputation!
GregsSD is offline
post #5 of 5 Old 08-23-2013, 01:53 PM
Raul@Stealth Automotive's Avatar
deaver springs are also one of the best.. they can custom make any spring height for your truck...
Raul@Stealth Automotive is offline
