3inch lift on 33's = sloppy steering - Ford Powerstroke Diesel Forum
post #1 of 16 Old 08-22-2013, 07:54 PM Thread Starter
just picked up a 01 excursion like an hour ago ....106k miles ....has a 3 inch lift on a set of knobby 33's ....since im new to the lifted truck world , I was told the tires are what caused the sway ....driving on the hwy , if I hit a bump or caught a grove in the road , it felt like it would steer itself ....also the steering wheel is crooked while driving straight ....I love the way it looks but im concerned to put my kids in the truck for safety reasons , could it be just the tires that cause this? ...anyone ever have a similar prob like this or knows steps to correct it ? I was thinkin start with an alignment
SUPRA180 is offline
post #2 of 16 Old 08-23-2013, 08:33 AM Thread Starter
anyone ? im trying to figure out if that's how lifted truck rides with big sidewalled knobby tires or maybe theres something I need to add .....I want it done right ...the guy said something about dropping the pittman arm ....not sure whats involved in that ...not sure if it helps but it looks the lift is a few blocks on top of the leaf springs and white struts with red boot covers
SUPRA180 is offline
post #3 of 16 Old 08-23-2013, 08:48 AM
Sounds like you need to have the front end checked out. Possible bad tie rods, ball joints, pitman arm.. or a combination of all of that.
My duramax has doesn't have 33 inch knobby tires so I'm not sure what it feels like with those type of tires.
Jon5212 is offline
post #4 of 16 Old 08-23-2013, 08:50 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
Steering Stabalizer?
2000-7.3L is offline
post #5 of 16 Old 08-23-2013, 08:55 AM
DBM
someone probably just put the lift on it and didn't get the steering wheel centered. An alignment shop can fix that, also curious if they replaced the track bar with an adjustable unit or a dropped trackbar bracket. I am no expert on lifts, but I don't think you need a dropped pitman arm on a 3 inch lift
"have not shot the gun yet but will next week when we see the mother in law." Quoted from a gun forum!
2004 CC 6.0 4x4 lariat
MODS: BPD Remote Oil Cooler, MTW Stage 1, GoGo Diesel Direct Drive Soleniod, Swamps 58v FICM, ARP's, Sinister EGR Delete, SCT XCAL3 w/DJ's Looney, Dfuser coolant filter, 4" straight pipe, Ranch Hand, Tuff-Country Level Kit, Isspro Boost/Trans Temp/Fuel Pressure/Pyro gauges, Edge Insight CTS...
DBM is offline
post #6 of 16 Old 08-23-2013, 09:25 AM
kirbybc12's Avatar
Wobbling is probably your track bar, I just ordered a front level kit from Carli for that same reason. I've started to hate driving my truck because of the wobble. The tires could also be the issue, what type are they?
2012 F-350 Lariat FX4 CCSB
2.5" Carli Commuter
Carli High Mount Steering Stabilizer
AFE Cold Air Intake
Truxedo Lo Pro QT
Line-X
Dura-Flap Mud Flaps
Timbren SES
High Idle
35x12.5x20 Toyo AT II Extreme
H&S Mini Maxx, 4" AFE Turbo Back
kirbybc12 is offline
post #7 of 16 Old 08-23-2013, 10:21 AM Thread Starter
Bf goodrich mud terrain TA 305/70/16. Says tri-cord 3ply sidewall
SUPRA180 is offline
post #8 of 16 Old 08-23-2013, 10:22 AM Thread Starter
Anyone have a pic of a trackbar ? Tryin to learn about all this suspension stuff
SUPRA180 is offline
post #9 of 16 Old 08-25-2013, 05:29 PM
The track bar goes from the frame to the axle. The drag linkk goes from the steering box more or less to the horizontal bar in front of the axle. Adjusting the sleeve on the drag link will center your steering wheel.
Being that Excursions are leaf sprung, I really doubt the track bar is that big of an issue, although an adjustable track bar wouldn't be a bad idea. However, considering how tight that bolt is at the axle, you may as well pay a shop to put one in.
I honestly believe it's a steering linkage issue: worn ball joints and/or tie rods ends. I have run 14.5 inch wide tires on my truck WITHOUT a steering stabilizer and it tracked just fine. In fact, I've owned my truck since July 2006 and it had a steering stabilizer on it for about 2 months before I bent the thing wheeling and NEVER replaced it. Hence my opinion that on a leaf sprung truck, a steerig stabilizer is a mask/Band Aid for the real problem.
Another thing to consider: is there is slop in the steering wheel? This can be fixed with a simple adjustment to the steering box.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #10 of 16 Old 08-25-2013, 07:18 PM Thread Starter
yes there is some slop in steering wheel .....the more I thought about it I was thinking tie rods or ball joints ....I have a real good truck shop to bring it to , only problem is they deal with stock fleet vehicles only ....not lifted ones , other than ball joints and tie rods , do you think they will be able to nail the whole issue down at once ? i guess my question is , is it something that a good mechanic can figure out or is it something you need experience with llifts to make proper adjustments ?
SUPRA180 is offline
