Rear Sway Bars ? Need or Not? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-22-2013, 04:43 AM Thread Starter
colonel angus's Avatar
Quoted: 2 Post(s)
Anyone taken yours off and what did you do to extend the end links past a 4.5" Lift?
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #2 of 6 Old 08-22-2013, 04:18 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
rear sway bar is only needed usually if u do a lot of towing, or your front sway bar still allows more body sway then u like. take t off and see how u like it. I run NO sway bars on my truck
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #3 of 6 Old 08-22-2013, 06:46 PM
897.3alltheway!'s Avatar
Quoted: 13 Post(s)
Denny
took my rear one off, works fine also took my front one off for a hile but my springs are so stiff there is no sway...my front sway bars i cut the links?? and extended them with a (forgot size) piece of tubing then welded it
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
post #4 of 6 Old 08-22-2013, 07:08 PM
ZMANN's Avatar
Quoted: 1784 Post(s)
I added them to mine I instantly felt a difference on a long sweeping onramp I take every day to work
as for the end links I cut them and sleeved them with 1/2 Iron pipe
to accommodate My 8 inch lift
We Miss you Ronnie
ZMANN is offline
post #5 of 6 Old 08-22-2013, 07:17 PM
Quoted: 13 Post(s)
thats exactly what i did on the front..just sleeved , but the rear of mine still have the helper spring so when towing that kind of acts like a sway bar?
-Jeremy
Got A Few Rides...
post #6 of 6 Old 08-22-2013, 07:22 PM
ZMANN's Avatar
I have rear airbags and those did OK at sway control
but I wanted to get as close to a dually without the extra tires so I added the Helwig sway bar LOL
We Miss you Ronnie
ZMANN is offline
