Anyone selling a lift kit? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-17-2013, 03:17 PM Thread Starter
StrokinInPublic's Avatar
I have a 01 f-350 super duty lifted 3 inch on 33s. I'm looking to go at least 6 inches, but I'm willing to do as large a suspension lift as possible without having to change everything under the truck. I want to put at least 38 inch tires on it. Can anybody help me out? Also tips to fit bigger rims and tires on my current setup? Not sure if a few inches of body lift will look bad with my current suspension lift. Thanks alot
StrokinInPublic is offline
post #2 of 9 Old 08-17-2013, 03:18 PM
BIG Laing's Avatar
Body lift is a bad idea.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #3 of 9 Old 08-17-2013, 03:25 PM
Jonboywv12's Avatar
Send a message via AIM to Jonboywv12
go in higher than 3 inches your probably guna be changing things underneath anyway to get the right pitch for the everything.
Jonathan or Jon
2002 F-350
4" Banks turbo back exhaust.w/5" tip
4" Banks down pipe
Banks Big Hoss turbo waste gate
6" SKY JACKER
35" Nitto All-Terrains
TW chip 6 pos.
Banks Trans-Command shift kit
AFE STAGE II Intake
Gauges (boost, EGT)
102" whip antenna (guaranteed 100hp!
enough for fun!
Jonboywv12 is offline
post #4 of 9 Old 08-17-2013, 03:42 PM Thread Starter
Even with a 6or8 inch lift?
post #5 of 9 Old 08-17-2013, 04:40 PM
Jonboywv12's Avatar
yes sir, cause right now track bar, pitman arm, and sway bars are all set at factory ride height. But if you go and lift it 6" or 8". all of those pitches and degress have to be relocated to adapt the new lift.
Jonathan or Jon
2002 F-350
4" Banks down pipe
6" SKY JACKER
TW chip 6 pos.
AFE STAGE II Intake
Gauges (boost, EGT)
enough for fun!
post #6 of 9 Old 08-17-2013, 05:28 PM
JustinOOO9's Avatar
Quoted: 476 Post(s)
Garage
got a 90% used 4inch of a 2001 f350 he ran 35's and i have been debating pulling my 8in superlift off for practicality. any interest in my 8in? has everything track bar, sway bar end links, front and rear springs no blocked needed pitman arm, shocks I might trade drive line too since mine was extended would take me about a week to get it pulled off I dont have tall enough jack stands so I would drop it off at 4wheel parts.
4in lift and 8in lift if ya interested pm me. for the 4in all you need is sway bar end links and bump stops and front u bolts. maybe a few bushing as usual etc...
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake.
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is online now
post #7 of 9 Old 08-17-2013, 11:12 PM
897.3alltheway!'s Avatar
Quoted: 11 Post(s)
yep , track bar , pit arm , brake lines , sway bar , carrier bearing i think ,
you could always just get bigger springs up front and or use blocks in the back (cheap way) but it works
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
post #8 of 9 Old 08-18-2013, 08:56 AM Thread Starter
How much would this cost?
post #9 of 9 Old 08-19-2013, 06:22 PM
Quoted: 11 Post(s)
depends what brand and size springs you get if you go that route and if you lift it yourself...if you do blocks in the rear it would be helpful to get traction bars to prevent axle wrap but it is up too you...
-Jeremy
Got A Few Rides...
