Turning 6 inch lift into 8 inch? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-16-2013, 08:33 PM Thread Starter
Super Duper Duty
00Turbo444's Avatar
I have a 6 inch procomp lift on my truck. I'm wondering if I need anything other than springs and blocks to make it into an 8 inch? Like longer pitman arm etc?
Thanks
Scott
08 VR F250 CCSB Lariat FX4
8" PMF 4 link
22x12 American Force Hero 37" Toyos
00Turbo444 is offline
post #2 of 6 Old 08-16-2013, 08:47 PM Thread Starter
Super Duper Duty
00Turbo444's Avatar
Truck is 2008 forgot to mention
Scott
8" PMF 4 link
post #3 of 6 Old 08-17-2013, 06:38 AM
Outback, an add-a-leaf would be best. I'm assuming that you have already stacked blocks to get to the 6 inch lift. Short of one single block to get that 8 inches of lift, an add-a-leaf and the existing stack should get you where you are trying to go. BTW, I f'in hate stacked blocks, 25 years ago, magazines wouldn't publish pics of your rig if it had stacked blocks because they are unsafe.
Up front, well, it's not quite so easy. With coils, simply putting in taller coils, or spacers fot that matter, has the equal and opposite effect of inducing negative caster. Negative caster is from the axle rolling forward when lifted. To correct this, you either need to add caster shims, or lower the trailing arms in the rear. Either of these will correct the negative caster that taller coils or spacers will induce.
Unless you go to a custom pitman arm, most "out of the box" lifts use the same pitman arm for 6 and 8 inch lifts. There will be enough adjustment in the drag link to compensate for this. This is one time when I think that an adjustable track bar AND a track bar drop bracket should be used. It is mucho importanto to keep the brag link and track bar parallel. Therefore, if you're not going to drop the pitman arm again, then don't dop the track bar again.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #4 of 6 Old 08-17-2013, 10:48 AM Thread Starter
Super Duper Duty
00Turbo444's Avatar
Thanks for the awesome reply. I was planning on getting a larger single block as like you said, I do have stack blocks which I do not like. I was planning on getting blocks but then found a set of brand new set of rize 8" coils for cheap and I was hoping I could throw them in without many more parts. I will do the cams. Any idea how big of a block I would need for the rear? Thank you very much
Scott
8" PMF 4 link
post #5 of 6 Old 08-17-2013, 11:12 AM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 79 Post(s)
Feedback Score: 7 reviews
Ditch the block and go with full springs at that height. Don't forget longer brake lines, abs sensors, drive shaft, etc etc
God bless America, the Constitution and the Second Amendment.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
powerstrokeshellback is offline
post #6 of 6 Old 08-17-2013, 11:20 AM
Having gone to a 6" lift spring, I'd say to use a PMF or OUO traction bar/block lift. Fabricated Unitized Floating Traction Block
Those factory springs are a good ride, but blocks induce wrap, so you install traction bars and that wrap is minimalized. For the amount of money that I spent on the Pro-Comp lift springs and traction bars, I could have bought this set up.
Karls03 is offline
