Cheapest way to get 35's to fit? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 08-16-2013, 01:39 PM Thread Starter
Just bought 4 wheels and tires 35/12.5r18. I have a 2002 Excursion and was wondering what the cheapest lift to get them to fit would be.
avx96 is offline
post #2 of 14 Old 08-16-2013, 01:52 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Pretty sure you can get them to fit with just a level kit but not 100%
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 14 Old 08-16-2013, 01:54 PM
c69ss396's Avatar
let me just say you get what you pay for. If you go cheap you WILL hate it, it will ride like crap and you will spend more money to fix all the problems you created by being cheap then you would have spent by doing it right the first time...
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #4 of 14 Old 08-16-2013, 01:59 PM
also depends on what offset you have
BlackNight60 is offline
post #5 of 14 Old 08-16-2013, 02:00 PM
HBandy's Avatar
I'd like to find this out too. I want to get 35's if they'll fit with just a leveling kit.
HBandy is offline
post #6 of 14 Old 08-16-2013, 02:10 PM
From what ive seen some guys make the 3.5inch lift work but its more for the 33's. you may have to go to the 5.5 to get good enough clearence.We sell the fabtechs for around $1700. My 02 f250 had to see a 6inch to get enough clearance for 35's.
I have the 8inch now and the 37s still rub the leaf springs and almost touch the rear of the front fender well.
post #7 of 14 Old 08-16-2013, 09:31 PM Thread Starter
I was looking at the rough country 5 inch lift. It's only about $800. Does anyone have experience with the rough country lifts? And some guys fit 35s with a 4 inch correct?
avx96 is offline
post #8 of 14 Old 08-16-2013, 10:25 PM
alaskan155's Avatar
Quoted: 60 Post(s)
rough country is bottom of the line lift kit, you get what you pay for which usually equates to a sacrificed ride,
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #9 of 14 Old 08-17-2013, 07:53 AM
kclough's Avatar
I installed a 2.8 leveling kit and had 315/75/16 on my stock wheels and the kit cost 80 bucks and only rub at full turn
kclough is offline
post #10 of 14 Old 08-17-2013, 08:06 AM
asian195's Avatar
Quoted: 2 Post(s)
I had a rough country lift on my jeep, I know it's no ex, but it sucked. Shocks were crap, they had horrible dampening. The spring rates were way off to. So the combined bad shocks and bad springs made it a very bouncy ride.
2003 F-350 6.0L.
Leveling kit
35/12.50-20 Federal Couragia M/T
20x10 black Fuel Hostage wheels
4"-5" exhaust no cat
Airaid intake
SCT tuner-awaiting custom tune
Edge Insight CTS
Blue spring
6.4 Banjo bolts
Zoodad mod
EGR Delete
To Do/Wish list:
FICM tune
ARP Head Studs
BPD Oil Cooler/Filter
Fog light mod
Harpoon mod
Injectors 155cc
asian195 is offline
