2013 F250 Pulling Questions? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 08-06-2013, 05:48 AM Thread Starter
I just bought a 2013 F250 with the 6.7 Powerstroke.
My father has a 7.3 with airbags and plug in chip and pulls our 35' Montana Fifth Wheel. I think the GVWR on it loaded is about 14-15000 pounds guessing on the heavy side.
This truck should be able to handle that without a problem correct?
I am putting the rails in for the hitch this weekend to pull the RV to Bristol at the end of this month for the NASCAR race so it will be through pretty dense mountainous terrain.
I am not chipping it due to the warranty. I work for a tractor company and make TSB's and find warranty glitches for a living so I know how it works I am not playing those games. 15k engine > 1k chip
Thanks for the help!
Tobacco Money Powerstroke is offline
post #2 of 2 Old 08-06-2013, 11:27 AM
ponyexpress94's Avatar
My suggestion is to get your hitch installed as you plan to and then hook up the trailer and take it for a short drive. Stop once or twice if you can to see how the truck sits while hooked to the trailer and see if you can live with it or not. Once you see the setup together will tell you whether you'll want airbags or not.
Oh yeah, double check the GVW of the trailer by looking on the VIN tag so you aren't guessing at the trailer weight. Better yet, on your test drive with the truck and trailer go weigh the whole setup on a truck scale to see what the total weight is.
Patrick
2003 F-350 CC LB XLT 4x4
Feb 2003 6.0 Liter Diesel and Torqshift 5 spd Auto
FS2500 Engine Oil and Transmission Bypass Filters
Dieselsite Coolant Filter
C-Betr Spot Mirrors
Ford AIC
Cobra 29 ST NW WX CB
Weatherguard 117 Toolbox
Weatherguard Weekender Ladder Racks
B & W Turnover Gooseneck
ponyexpress94 is offline
