icon vs king - Ford Powerstroke Diesel Forum
post #1 of 17 Old 08-05-2013, 01:36 PM Thread Starter
icon vs king
so ive been looking at shocks for my truck for a little while now and i have come to the conclusion that i shouldnt skimp here. could something like a bilstein 5160 be good enough, maybe or maybe not. id rather spend a little more and get something that i know will do what i want, control the big a$$ truck. so that brings me to this. i have an 8" icon lift: icon dual rate coils up front and their plush ride leafs in the rear. so naturally i'd give icon a shot at the shocks. i want a 2.5" shock. icon offers a 2.5" with and without a resi with a price difference of about $120. from what i have seen the 2.5" kings only come with a resi and run about $950 per pair. both are rebuildable and both are custom valved. so which one is better? the icons would run me $1640 (resi front and no resi rear) and the kings would be $1900.
also trevor at PMF has informed me about his custom race series shocks made by a company called ADS. 2.5" runs $350 with out resi and $400. i cant find much about these guys in the superduty world so im a little hesitant about going with them. i know trevor is a good guy and sells a quality product so id think they would be a good product.
anyway fire your opinions away and let me know what you think is the best shock for a 90% pavement truck looking to smooth things out. thanks
06 f350: 8" ICON 2.5 resi's, ouo ala's, pmf track bar, dual stabilizers, custom 5" exhaust, 37" BFG km2's, 4.30s, 08 tailgate w/step, 08 tail lights, coolant filter, BPB oil cooler w/p 58v ficm and radiator, ARPs, 175cc, MTW s1 billet, ported intake, egr delete, onboard air and gearhead tunes
All the above just to haul the 900hp street mustang
94slowbra is offline
post #2 of 17 Old 08-05-2013, 02:38 PM
layson's Avatar
Quoted: 83 Post(s)
I would run the icon shocks with reservoirs, it is an icon kit. You won't have to mess with valving them. You can call them and they will help you out. Icon is a great company and good people working for them. I would skip the reservoir rears, not worth it in my opinion.
If you just want bling then go for the king's....
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #3 of 17 Old 08-05-2013, 05:36 PM Thread Starter
ive spoken with icon and king, both very knowledgeable and helpful, and also with a couple of third party companies to get their opinions. i was leaning towards the icons but then i ran across the kings for not that much more and know they have a good rep. i like that fact that the icon shocks valving would mate perfectly with the icon springs, just didnt know if the kings were that much more of a shock for a few bucks more.
i agree that i dont need a reservoir in the back, still not sure i need them in the front, thats why im looking for peoples experience and thoughts. for me bling is not nearly as important as function. thanks for your input
post #4 of 17 Old 08-05-2013, 05:47 PM
layson's Avatar
Quoted: 83 Post(s)
There is also a difference in internal shock geometry as well that would push me towards icon. Just pull up the spec sheets for the shocks and you will see.
Quote of the Day:
layson is offline
post #5 of 17 Old 08-05-2013, 06:04 PM Thread Starter
Can you elaborate a little? I don't know much at all about shocks which is why I've been having the internal argument for a couple of weeks now. I could pull the sheets but I need it in dummy terms to understand probably. Thanks
post #6 of 17 Old 08-06-2013, 12:21 PM
layson's Avatar
Quoted: 83 Post(s)
Just look at compressed and extended length for the same exact size shock. King is different than practically everyone else, essentially less travel for the same size shock. Most the time it really doesn't matter, but it does to me.
http://www.kingshocks.com/products/p...formance-race/
Quote of the Day:
layson is offline
post #7 of 17 Old 08-07-2013, 08:37 AM Thread Starter
so no one else on here has high end shocks and has an opinion on them?
post #8 of 17 Old 08-07-2013, 03:16 PM
Icon makes a great shock. If you already have Icon's coil springs, get the shocks that match the spring rate+ the truck there on. I don't get the King= bling, King shocks are race proven. Both can be re built and tuned, same with Fox. As far as reservoirs, they let the shock shaft travel completely into the shock body, letting the fluid compress into the res. A second benefit is cooling due to more fluid and the remote res being further away from the shock body where the heat is generated. Depending how the amount of travel your suspension has, the shock my not need to travel far enough to justify having the res.
BTW, love that 'Stang, notches are my favorite Fox-body
See you in the Dirt!
76hauler is offline
post #9 of 17 Old 08-07-2013, 03:32 PM
layson's Avatar
Quoted: 83 Post(s)
I would say they are bling, they are shiny and have a nice blue color to them! I bet a lot of people buy them just because of that.
No question that they make a great shock, but for this application it doesn't make sense to me. Unless you want that look...
Quote of the Day:
layson is offline
post #10 of 17 Old 08-07-2013, 06:31 PM Thread Starter
Good point about the reservoir letting the shaft travel all the way into the shock body, I did not know that. I know about the cooling, I don't see my truck needing the extra cooling. Does the resi allow for better dampening overall of just in extended use when the oil gets hot? Again I'm not going yo use the shocks enough to need extra cooling.
I'm leaning more towards just 2.5 smooth body icons all around. Should be good for my application and much better than my crappy bilstein/edelbrock combo I have now.
The stang use to be the toy, the 350 has seemed to take over recently. Funny how that happens
