4 inch to a 6 inch questions - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-02-2013, 04:01 PM Thread Starter
chris-rector's Avatar
Ok I have a 2003 ford F350 my truck has a 6 inch lift but it was a spring only lift from a 4 inch lift do I need to change the pitman arm or anything? It drives ok it was done before I bought it 3 1/2 years ago tires wear is great just wondering...
Chris
<a href="http://truckprofile.com/members/chris-rector/Ford-F350-2003/694">My Truck Profile</a>
chris-rector is offline
post #2 of 5 Old 08-02-2013, 04:05 PM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 1034 Post(s)
Feedback Score: 6 reviews
I deleted your other thread for you.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is online now
post #3 of 5 Old 08-02-2013, 04:10 PM Thread Starter
Thanks Rattlesnake
post #4 of 5 Old 08-02-2013, 08:16 PM
RIP Cam!
No problem.
post #5 of 5 Old 08-03-2013, 06:35 AM
What's the length of your pitman arm from the box to the drag link end? Also, if you can post a pic of a common place to measure the track bar drop, that would help too. I'll compare these to mine with a 4 inch lift for an answer. The fact is, it could be the same pitman arm and drop bracket for a 4 and 6 inch lift.
Karl
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
