Carli options - Ford Powerstroke Diesel Forum
post #1 of 15 Old 07-29-2013, 01:59 PM Thread Starter
Carli options
Im the new guy here. Been following the forum for a while now and finally decided to be apart. I have a 2011 F250 FX4 that is my daily driver. I dont do much off roading with the truck, mainly just the gravel roads in the Texas hill country getting to and from the ranch. I am not very happy with the stock ride on the truck and am looking to upgrade. The truck is stock now with exception of 285/75R18 GY OC AT/2 wrapping BMF novakane 18x9s. I am leaning towards the carli systems but not sure which one yet. I am pretty sure I want to go with a 4.5" system but not 100% yet possibly a 2.5". I am looking for improved ride quality around town on the road, which I am sure will also help out the short periods of time cruising those gravel roads around the ranch as well. Any info yall can provide would be greatly appreciated.
CWF0705 is offline
post #2 of 15 Old 07-29-2013, 02:15 PM
As an owner of the same truck, and a Carli 2.5" Starter System, I would go with the 2.5" King Pintop setup if I could do it again. The starter system is nice, but the Bilstein 5100 shocks leave a little to be desired once they break in. From what I have been told, going from the Bilstein 5100's (Starter System) to the King Pintops is definitely worth the extra money.
I was looking for the same type of results, a better ride around town and a little bit of gravel here and there.
Redwood Original is offline
post #3 of 15 Old 07-29-2013, 03:12 PM
I'm in the market as well. I have no first hand experience but from all the reviews I've read you want a minimum of the Backcountry 2.0 with the Bilstein 5160's and full replacement deaver spring pack in the back. Most say the Pintop 2.5 with King shocks are worth the extra money if you can swing it.
thedude1980 is offline
post #4 of 15 Old 07-30-2013, 09:31 PM
Skyd Ram's Avatar
Quoted: 131 Post(s)
Based on the tire size that you are running I would go with the 2.5" Pintop kit. The 4.5" kit will make those 34.8" tires look pretty small. As long as you keep the tire pressure down around 40-45 front and 35 rear you should be very impressed with the ride of the Pintop kit both on the street and in the dirt.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is offline
post #5 of 15 Old 07-31-2013, 11:28 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
You may also want to look at a kit with 4 link arms..will ride better than any kit using stock arms..Pure's and Icons.
CT Performance, Inc. is offline
post #6 of 15 Old 07-31-2013, 12:35 PM
rstarr harley's Avatar
Is there something wrong with Carli products? Not trying to stir the pot but almost every Carli post you always push other products. Like i said not trying to start any arguments im just trying to figure out why you think Carli doesnt offer a good enough product.
2013 F250 Plantinum Carli 3.0 Dominator 37in Toyo M/T's
18X9 BMF Novakane stealth's
2011 F350 KING RANCH
Carli 2.0 4.5in w BMF 20X9 Novakanes 35in Toyo M/T'S
2009 F250 HARLEY DAVIDSON
2004 F250 HARLEY DAVIDSON
12 inch Icon With 20in Mazzi hulks with 40in Toyo M/T'S
2002 F250 LARIAT
18in custom lift with 44in Super swampers
2001 F350 LARIAT
rstarr harley is offline
post #7 of 15 Old 07-31-2013, 01:14 PM
TripleE44's Avatar
That's just what he does with any suspension company he doesn't sell. Say's they won't work or ride as good as the stuff he sells.
11 F250 6.7 CC/SB -- tuned & deleted -- 3.5'' PMF/ICON/Fox suspension, Method Standards, Toyo AT2s
TripleE44 is offline
post #8 of 15 Old 07-31-2013, 02:53 PM
Quoted: 3 Post(s)
Never said their products were not good, what I have said is that until the factory radius arms are replaced your stuck with its design limitations. Lack of castor adjustment, pinion and castor changes as the suspension cycles and the binding from the joints ..compared to a 4 link.
Same thing I have said about any manufactures kit, Pure and Icon both have kits that use std radius arms and have the same issues.
New arms cost more that's why its a harder sell over std kits but when someone wants the best they will need them.
post #9 of 15 Old 08-01-2013, 07:42 AM
Pure Perf's Avatar
Like George mentioned. For that size of tire on an 08+ you are only going to need a 2.5" lift unless you plan on upgrading to 37's down the road. Then going with a 4" or 4.5" makes sense.... If you have any questions on our Pure Performance Products please let me know...
JP
www.pure-performance.biz
Pure Perf is offline
post #10 of 15 Old 08-01-2013, 02:48 PM
Skyd Ram's Avatar
Quoted: 131 Post(s)
How fitting was this pic that I found and posted on out FB page?
888-886-2480
Skyd Ram is offline
