Lift questions - Ford Powerstroke Diesel Forum
post #1 of 16 Old 07-28-2013, 10:49 PM Thread Starter
dieselforce's Avatar
Lift questions
I am looking at doing a suspension lift and leveling kit on my 06 F250 4x4 crew cab. It is a 2.5" lift in front and a 1" lift in the rear. I was wondering how much this will actually affect my ride height? I'm also putting 33" tires on it so I don't want it to be too high being that I tow a travel trailer and a large boat plus I have 4 young children so I want them to be able to get in without much difficulty. Is it worth lifting at all or should I just stay stock height with the 33" tires to get my added height?
Next question is would the 33" fit on the stock truck? I am looking at 285/70r17 for the tire size
06 F250 XLT Crew Cab 4x4
6.0l Powerstroke Diesel
Suspension Maxx 2" lift/level kit
17x9 KMC XD Series Hoss rims
LT285/70R17 Toyo Open Country AT2 tires
SCT X3 programmer running Innovative Diesel Custom Tunes by Eric
MBRP Performance 4" turbo back muffler exhaust
Cat delete
Carpet Delete
Truxedo Bed Cover
dieselforce is offline
post #2 of 16 Old 07-29-2013, 12:11 AM
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
A 2.5 would be fine with 33s you can go up to a 35in tire.
I say do it!
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #3 of 16 Old 07-29-2013, 12:09 PM
colonel angus's Avatar
Quoted: 2 Post(s)
I have a kit if your interested, Machined blocks that go under the front springs and a 1" block for the rear with the center pin.
It's not a big enough difference to notice when driving but you will stump your toe a time or two on entry and exit.
Word of Caution....
Leveling Kits normally leads to 4" kit and 35's !!!!!!!!!!!
d
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #4 of 16 Old 07-29-2013, 07:29 PM
Quoted: 2 Post(s)
PM and Email Sent.
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
post #5 of 16 Old 07-31-2013, 10:43 PM Thread Starter
Will 33" tires mounted on 17x8 rims fit my truck with stock suspension without rubbing?
Cat delete
Carpet Delete
Truxedo Bed Cover
post #6 of 16 Old 07-31-2013, 11:07 PM
jlmotox's Avatar
Should, I had 35's on stock wheels fit fine.
Sent from AutoGuide.com App
2005 F250 Lariet FX4 CC SB 6.0, 6" ProComp Stage2 Lift,17x9 ProComp wheels,35" ProComp xtreme AT's,Warn 12k winch w/hidden kit,Custom light bar w/4-8" ProComp,Pioneer double din Nav XM back up cam,10" kicker sub,1000w 5channel amp,15% tint, Truxedo bed cover,Firestone Bags,Airaid intake,4" turbo back MBRP exhaust,ARP headstuds
jlmotox is offline
post #7 of 16 Old 08-01-2013, 07:05 AM
Quoted: 2 Post(s)
It depends on the offset, the contact point is the inner fender just inside the lip.
Stock wheels have a 4.75" back spacing OEM come in +18 which are closest to Factory at 4.5" back spacing to -12 for 9" and -24 for 10" which STICK Out further.
It's a give and take as to where the contact is going to be.... control arms or fender plastic once you go 12.50's and 35".
You can drill a small hole in the bottom of the flare and zip ties it back to the support or trim off about an inch with dremel tool or sheet metal shears.
Some trucks can run 35's on stock wheels without any problems, and 37's with a level kit.
Others not so much.
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
post #8 of 16 Old 08-01-2013, 10:37 AM
onebadcoastie's Avatar
Quoted: 10 Post(s)
I got a wild hair yesterday as right now I have 2.5" CST springs up front and plan on 18x12 with 33x13.50's. I considered a 2" spacer for a total of 4.5" and running a 36x15.50. Just unsure right now.
Shack
2016 F-350 CC Dually
2005 F250 CC FX4.SOLD
onebadcoastie is offline
post #9 of 16 Old 08-02-2013, 07:25 AM
Gearhead2012's Avatar
Quoted: 2 Post(s)
Everything is a trade off, a compromise. You gotta look at how you plan to use it. I go down to the beach a lot, camping, plus my property has some really soft spots in it that I drive over somewhat regularly. I'm a big guy (7feet) so getting in and out isn't too bad for me...my wife on the other hand isn't so lucky, thank god for oh sh!t handles. I don't mind the trade off of functionality vs inconvenience, bit I wouldn't go much bigger than 37's and 6.5-7" of lift I got now, works well for what I need it for, still tows fine, and the looks aren't a bad byproduct either. Its all up to you and how much benefit you'll get out of it. Personally if I was going to go through the trouble at all, I'd at least to with 35, not a huge jump from stock, but enough to be worth it. I cleared that fine on stock Harley 20's with a leveling kit...I also added a taller block to the rear, I think most leveling kits don't level, I think they make the back end sit lower...which isn't a look I care for.
2005 F-250 Harley Davidson Edition
6.0 cylinder heads and custom engine building available
Under construction
Warren 205/75 Injectors
Icon 4 Link, 37" Nitto's
SSBC 6 piston calipers
Yukon 4.30's, Detroit Locker
Machining the 6.0:
Gearhead2012 is offline
post #10 of 16 Old 08-02-2013, 07:58 AM
sfu7274456's Avatar
I run 38X15.50 with 20X10 XD Diesel rims with a leveling kit and cut out fender flares. But I also beat my weld seams flat so I could zip tie my inner fender wells up as high as possible. I must be one of the lucky ones because I seem to be able to run bigger than most with just some leveling pucks. It just really depends on your truck. I tow with mine including a fifth wheel with no problems.
Ignore the pick below that is before I upgraded to 38's
sfu7274456 is offline
