Shaking - Ford Powerstroke Diesel Forum
post #1 of 11 Old 07-24-2013, 06:47 PM Thread Starter
new2deisel's Avatar
Shaking
I get a lot of shaking in my truck when I get to 75-80mph. Is it possible my driveshaft carrier bearing needs to be lowered some?
new2deisel is offline
post #2 of 11 Old 07-24-2013, 07:04 PM
897.3alltheway!'s Avatar
Quoted: 13 Post(s)
what do you mean by shaking??
front tires shaking? lots of vibration?
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
post #3 of 11 Old 07-24-2013, 08:45 PM Thread Starter
new2deisel's Avatar
More vibration and not from front end. When I say shake I mean my center console shakes.
post #4 of 11 Old 07-26-2013, 05:57 PM
Interested in the answer here. I have the same vibration at 75. Can watch the passenger seat shake.
2004 F350 4x4 (155,000)
6.0 turbo / automatic
studded / deleted
gtmgooser is offline
post #5 of 11 Old 07-26-2013, 07:45 PM Thread Starter
new2deisel's Avatar
I've been too lazy but I need to lower my carrier bearing a little more and see what happens. Or might need some degree shims.
post #6 of 11 Old 07-27-2013, 08:26 AM
I get a shimmy too ever since I lifted my truck and put the big meats on.
I have it shimmed, balancing beads, and centramatic balancers.
Still have the shimmy but not as bad. My shimmy starts around 45 and continues. 70 is more noticeable than 45-50. I do not know whats going on but drives me nuts. Sometimes I feel like a dog wagging its butt.
I might try rotating my tires 180deg. I have no play in the front, not weird tire wear or anything. The whole truck seems to do it like the op and get a very slight shimmy in the steering wheel cause of it. Tires appear to roll smooth and straight, nothing obvious. Might need dual stabalizers, idk.
Curious what you guys find on yours. Maybe angled blocks or shims. I only have 3in over stock in the rear and 5 in the front. I might try 2rear and 4 front to see if anything changes. Or even go back to stock in the rear to eliminate carrier shims to troubleshoot the issue.
Will keep an eye on this thread to see what you guys find
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)315's
PHP/Beans tuned, 250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system w/RR & FB Delete, Pius LASB from Irate, Swamps hvhf IDM
Autometer Nexus Guages (TT,FP,BP,EGT), 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line, Baldwin PA2818(6637) RR Boots, 26 row 6.0 Tranny & PS Cooler, LarryB's Denso Starter
INFRNL is offline
post #7 of 11 Old 07-27-2013, 08:40 AM Thread Starter
new2deisel's Avatar
Looked at it more closely this morning cause I was planning on shimming the bearings some and it turns out the rubber around the bearing is shot so I will start by replacing the bearing. Have to do front brakes on my wife's car first so not sure if I'll be able to locate a bearing and do it today.
post #8 of 11 Old 07-27-2013, 04:30 PM Thread Starter
new2deisel's Avatar
I was able to replace carrier bearing and lowered it 1/4", took it for a drive and it is much better. I may try lowering it a little more and see what happens. Only slight vibration past 80mph.
post #9 of 11 Old 07-27-2013, 04:33 PM Thread Starter
new2deisel's Avatar
If anybody is interested I googled what it would take to replace carrier bearing and found this thread, piece of cake.
Carrier Bearing Replacement - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #10 of 11 Old 07-28-2013, 06:31 AM
The best thing to do when lowering a carrier better bearing is to degree or clock it. Pushing it straight down will bind it. Look at the carrier bearings on a 550 or 650.
Karl
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
