Powder coat frame - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-23-2013, 05:32 AM Thread Starter
robts's Avatar
Powder coat frame
I'm getting ready to powder coat everything under my truck. Redoing my lift and putting a 4 link front suspension all chrome and powder coated. Even the axles and bolts getting coated. My frame Isn't rusted just has that stupid rubber coating. Trying to decide if I should bite the bullet and pull the frame off too.
Any thoughts
2004 F-SVT Lariat 2005 CR Cummins conversion with destroked motor mounts and tach module.ARP Studs;Hamilton springs and pushrods;WickedDiesel DragonSlayer CP3 and 5x10.5 inj;Tsperformance MP8; Smarty S06 TNT-R;Speraco Inercooler; Opie Water by-pass;DTT intake elbow; TwinTurbos and 2nd gen manifold.Grandrock 7" stacks;ATS Stage V 48re;4.56 gears with Detroit truetrac. check out in September Diesel Power 2009
robts is offline
post #2 of 3 Old 07-24-2013, 01:37 PM
RHKA's Avatar
Damn sounds like a project. Goodluck
2008 F-350 LARIAT CC LB DRW 4x4
6" FABTECH LIFT
22" AMERICAN FORCE RIMS, TOYO OPEN COUNTRY A/T LT325/50R22
SPARTAN TUNER(300 HP TUNE WHEN EMPTY)
5" DIAMOND EYE EXHAUST TURBO BACK
RHKA is offline
post #3 of 3 Old 07-25-2013, 10:30 PM
Quoted: 18 Post(s)
I would not powdercoat the frame because when it chips, moisture might go under it and rust will start to build up. And removing or fixing the powdercoat needs a lot of work.
truckfan is offline
