alignment issues? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 07-20-2013, 10:59 PM Thread Starter
jmeaby's Avatar
Quoted: 16 Post(s)
alignment issues?
I have a 2004 f250 stock height and265/75/16 with factory rims. I have recently put new upper and lower ball joints and new wheel bearing/hub assembly. had it realigned after I did the work. now even after all this I need to turn my wheel a little to the left to keep it going straight. if I have the steering wheel straight it goes off to the right, and at times the ride becomes bumpy as if my tires were cupped really bad, but they are not. any help would be great. thanks in advance.
04 f250 cc sb.
Egr block off, 4 inch turbo back ss magnaflow exhaust, billet turbo wheel, 05 Harley headlights, S&B intake, XDP coolant filter, tuned with Sct by PHP, BDS Dual rear add a leaf, Firestone ride rite airbags, 2 12 inch kicker subs, infinity rear speakers, mb quart frontdoor speakers, mb quart amp, autopumpkin Android headunit, torque pro.
jmeaby is offline
post #2 of 10 Old 07-22-2013, 12:22 AM Thread Starter
jmeaby's Avatar
Quoted: 16 Post(s)
Anyone ever have similar problem
04 f250 cc sb.
jmeaby is offline
post #3 of 10 Old 07-22-2013, 02:52 AM
shawnb99's Avatar
I would start by doing your own alignment....these trucks are simple to do.
If it is still an issue, look at adjusting your steering box, and start saving for a replacement box.
04 F-250 CCSB 4X4 6.0L Auto, tweaked by GEARHEAD
follow link to truck for sale
shawnb99 is offline
post #4 of 10 Old 07-22-2013, 09:58 AM Thread Starter
jmeaby's Avatar
Quoted: 16 Post(s)
May be a dumb question but what does the steering box do
04 f250 cc sb.
jmeaby is offline
post #5 of 10 Old 08-05-2013, 08:36 AM
atwelve's Avatar
I have the same year truck and dealing with a similar problem. The tire shop told me that my Camber is out, that I'll need 2 degree shims on the right side. It started out as a shimmy at 65 mph then notice that the tire was wearing on the inside. Haven't installed the shims yet but hoping to later this month. Hope this helps.
atwelve is offline
post #6 of 10 Old 08-05-2013, 03:47 PM
what are the specs? they should have given you a printout. If camber or caster are out on one side that will cause a pull and will need the correct bushings to get it in spec. The only adjustment from the factory is toe and that will not cause a pull. If camber and caster are good try swapping the front tires I do alignments everyday and 80% of the time it is a tire causing the pull not the alignment.
PowerstrokeAaron is offline
post #7 of 10 Old 08-05-2013, 05:03 PM
What he said.
What if the steering wheel is simply off? My wheel is tilted because I am too lazy to get under there and adjust the drag link to make it straight again.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #8 of 10 Old 08-05-2013, 05:05 PM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 122 Post(s)
Feedback Score: 7 reviews
I have the same problem but mine is an 07 with out leafs
God bless America, the Constitution and the Second Amendment.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
powerstrokeshellback is offline
post #9 of 10 Old 08-05-2013, 05:45 PM Thread Starter
jmeaby's Avatar
Quoted: 16 Post(s)
They adjusted the toe just a little he said and it actually helped, but they agree with me that what it does now is seem to wander with the road but should stop as tires wear in more. All alignment is in spec. I had a tire out of balance and that jacked up steering
04 f250 cc sb.
jmeaby is offline
post #10 of 10 Old 08-11-2013, 05:47 PM
Power$troke's Avatar
Quoted: 2 Post(s)
Garage
When you put the upper and lower ball joints in did you install them correctly...There is a specific order to installing them. I had to pull mine out and reinstall them. Make sure you grease and articulate the ball joints before installing them in the knuckle.This corrected my wandering issue. Napa has a great video on installing them.
2006 6.0 SD Crew Cab Lariat "Bullet Proofed"
8 inch Kit
Dual Steering Stabilizers
Adjustable Trac bar
37" Trail Grapplers
20X12 Armour Rims
ARP Studs
SCT X3
XDP EGR Delete
Edge Evolution
BPD FICM
PM Coolant filter
MBRP 4in Exhaust
Blue Spring Mod
High Idle Mod
HID 6k headlights / 23" LED Light bar 9000 lumens
Rock LED Lights in each fender well
Oracle LED wheel Rings (White LEDS Only)
LED BED Lights
Horn Blaster Horns
200psi 13 gallon on board Air system
Power$troke is offline
