front track bar - Ford Powerstroke Diesel Forum
post #1 of 13 Old 07-17-2013, 02:13 PM Thread Starter
front track bar
Im putting a 6" lift on my 2000 f250 and I can't seem to get the track bar to reach I installed the drop bracket that was supplyed with the kit is there a trick
2000 f250 7.3 airade intake 4" mbrp straight pipe bully dog diesel tuner gt with Harley-Davidson f350 interior
boboridesthefa is offline
post #2 of 13 Old 07-17-2013, 04:12 PM
Try compressing the suspension. If it still doesn't work, call the lift manufacturer and ensure that they sent the right part. Mistakes happen and slamming in an adjustable track bar before finding out if it's even the right drop bracket doesn't solve the big issue.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #3 of 13 Old 07-17-2013, 05:01 PM Thread Starter
I have tried to compress the suspension its still like 1/2" off even when I pulled the track bar off I.had a hard time pulling the bolt out and the drop braket is the right one
post #4 of 13 Old 07-17-2013, 05:04 PM
If you're saying that the initial removal of the track bar bolt was difficult, then your track bar could be bent.
Karls03 is offline
post #5 of 13 Old 07-17-2013, 05:10 PM Thread Starter
Would it help if loosen the u bolts to the rear and does it make a difference witch way it goes cuz I notice it has a stamped and b stamped on eaither end
post #6 of 13 Old 07-17-2013, 05:17 PM
I think we did the track bar first then the axle on my lift. It's really hard to arm chair this, putting the front end together is always a PITA! Now that you mention it, I'd try loosening up all of the u-bolts and pin the track bar first.
Make sure your track bar bracket is TIGHT! Mine loosened up and make a popping noise.
Karls03 is offline
post #7 of 13 Old 07-17-2013, 05:19 PM Thread Starter
Ok sounds good I dident put the track bar In first cuz my new bushing did not arrive in time thanks again ill let you know how it goes
post #8 of 13 Old 07-21-2013, 02:27 PM Thread Starter
Ok so I loosed the track bar bracket and loosed all the u bolts on the axle. Started the lower track bar bolt got the top pretty close and took a small pry bar into the back of the track bar bracket and pushed until the bar lined up the the hole on the bracket and and put bolt in and removed the pry bar used light hammer and taped the rest of the way to get the nut started then re tightened all bolts I had loosesnd thanks for the help
post #9 of 13 Old 07-21-2013, 02:50 PM
glad to help
Karls03 is offline
post #10 of 13 Old 07-21-2013, 03:20 PM
juniorssrollin's Avatar
Quoted: 2 Post(s)
Kind of off topic, but how tight does that track bar need to be on the drivers side frame mount portion? Noticed a minor popping in the front end
Sent from AutoGuide.com App
2005 F350 CCLB FX4
juniorssrollin is offline
