Loose Steering...? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 07-14-2013, 06:12 PM Thread Starter
Dont Mess With Texas!
ThirdCoastStroker's Avatar
Quoted: 14 Post(s)
Loose Steering...?
I have noticed my steering has gotten a little on the loose side compared to what it used to be. Any ideas on how to tighten it back up? mods are 2.5" leveling kit (newton lift) and 35x12.50 on stock 20"s this didnt happen after the lift, that was well over a year ago I leveled it and its just now starting to get loose. Any ideas would be great.
Casey
New Truck
15' F-350 King Ranch 4x4 CCLB
Platinum White / Caribou Metallic
Stock for now!
Old Truck
08' F-350 King Ranch 4x4 CCSB
H&S Mini Maxx 300 HD
5" Straight Pipe to 7" rolled tip
AFE S2 PDS
ARP Head Studs
FloPro EGR Delete with Intake Elbow
FloPro CAC pipe
Rebuilt beefed up OEM Up pipes
Deisel Site Coolant Filter
Firestone RideRite Airbags
Leveled
35X12.50R20 ProComp Xtreme A/T
Ranch Hand Front and Rear Replacement Bumpers
ThirdCoastStroker is offline
post #2 of 12 Old 07-14-2013, 08:23 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 465 Post(s)
Garage
You need to figure out what is loose. Take a look at the steering box first, can you move the steering wheel side to side before the pitman arm moves?
Track bar can also wear on the bolt at frame mount and give a loose feeling.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
post #3 of 12 Old 07-16-2013, 08:20 AM
what do you mean by track bar?? I've had a similar problem, and I can't decide whether the play is a result of the power steering pump or the gearbox any help would be appericated
steve349 is offline
post #4 of 12 Old 07-16-2013, 05:49 PM
shawnb99's Avatar
the track bar locates the axle side to side,
to the OP, the tire and lift combo IS probably the culprit, the effects of large tires are not overnight issues, but rather accelerated wear of items....specifically steering.
04 F-250 CCSB 4X4 6.0L Auto, tweaked by GEARHEAD
follow link to truck for sale
shawnb99 is offline
post #5 of 12 Old 07-16-2013, 06:32 PM Thread Starter
Quoted: 14 Post(s)
Yeah I understand the bigger heavier tires are probably the reason, but what I want to know is, what did the bigger heavier tires wear out so i can fix it? without taking it to a shop to have it done. I would like to try and fix it.
Mhatlen, I will have to take a look at that. thanks
Casey
New Truck
Stock for now!
Old Truck
AFE S2 PDS
ARP Head Studs
FloPro CAC pipe
Leveled
post #6 of 12 Old 07-16-2013, 07:39 PM
mhatlen's Avatar
Quoted: 465 Post(s)
Garage
I need to take a look at the bolt on mine, I am getting a rough yank and feel the front axle rack on me at times when I hit a big dip or big bump.
I can tell you my steering box had some play in it and I only have 84,000 miles on the truck. I grabbed the allen wrench and the 3/4 wrench and went about a 1/8 of a turn on my thrust bearing in the steering box and cinched up the nut tight and what a difference that made.
I can tell you 38" tires are more than these trucks like and I drive it very easy. Been thinking about putting a couple of additional cross members in under transfer case area and at the radius arm mounts. I can feel the trucks frame flex more so since I went with 38's over the 37's. There is a big difference, just the weight of the tires is 35lbs and I felt it immediately in both frame flex and the brakes.
I have 30,000 miles on them and I'm guessing they are going to go at least another 20,000 so I am going to stiffen this thing up and see how it likes it.
I am looking at running a piece of 3" tube from radius arm mount to mount. Tie both of them together and run cross braces to the transmission cross member. That will firm up the entire front rails and engine mounts etc. I'm sure you feel the frame gallop at times, these frames need to be stiffened up a bit.
Next set of tires are going to be Terra Grapplers 36"/14/18 not sure if they will last like the Toyo's but holy cow at 105lbs they are too much for even the Dana 60 IMO.
Ok I'm done ranting, check the track bar bolt and steering box for play first.
7" Icon/Carli Lift
Atlas40
mhatlen is offline
post #7 of 12 Old 07-17-2013, 10:42 AM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
A good way to find which parts are worn out is to have someone keep turning the steering wheel back and forth while you lay under the front of the truck and watch each joint from the steering box down to the tie rod ends.
You will be able to see which joints have excess play in them and need to be tightened or replaced.
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Bulletproof EGR cooler, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #8 of 12 Old 07-25-2013, 04:43 PM Thread Starter
Quoted: 14 Post(s)
Forewarning, I dont know crap about suspension.
I did the steering wheel side to side test and the (i think its called) pitman drop arm that comes out of the steering box moves perfect with the wheel, but where it is bolted to the bar that that pushes the wheels side to side that bolt/bushing combo seems loose has a little play to it.
Casey
New Truck
Stock for now!
Old Truck
AFE S2 PDS
ARP Head Studs
FloPro CAC pipe
Leveled
post #9 of 12 Old 07-25-2013, 09:20 PM
mhatlen's Avatar
Quoted: 465 Post(s)
Garage
Replace it. My steering is tight as a tick now.
7" Icon/Carli Lift
Atlas40
mhatlen is offline
post #10 of 12 Old 07-26-2013, 09:55 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
That is the drag link right?
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
