Steering problem need help - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-14-2013, 06:14 PM Thread Starter
I just finished putting a power steering pump on and the truck was turning fine but I was going down the road and let off the gas and the steering got tight and brakes quit working. Does anyone know if this could be a hydro booster problem?
Gibbons06 is offline
post #2 of 3 Old 07-14-2013, 09:24 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 449 Post(s)
Garage
You may still have some air in the system
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
post #3 of 3 Old 07-15-2013, 02:30 AM Thread Starter
I've tried what it said do where you turn the wheel left and right all the way and open the power steering cap. Someone said there is a tool you put on that cap and it forces the air out
Tags
brakes , steering
