Alignment after lift question? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-11-2013, 03:52 PM Thread Starter
Stoneguy1000's Avatar
I just purchased a 06 F250 lariat fx4 with a 6" fabtech radial arm lift. It's a great lookin truck and rides really well. My only issue is that it wants to pull to the right pretty good. I have had three alignments done to it and none have corrected the problem, nor do they know what the problem is. This is where I could use some help from someone with more knowledge than myself about this kind of issue.
I did see something about being able to adjust the radial arms to possibly fix this issue. Could this be true? All the alignments have only been on the wheels like a normal vehicle. Look forward to some input. Thanks.
Stoneguy1000 is offline
post #2 of 7 Old 07-11-2013, 04:42 PM
I faintly remember another member having s similar issue.
It ended up being the camber/caster bushings. Not sure what they are called exactly. I believe they are nylon or similar and go under the nut for the top ball joint.
That guy had his truck to the alignment shop a few times too but never checked those. After replacement, all was good.
Might ask them about it, idk
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)315's
PHP/Beans tuned, 250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system w/RR & FB Delete, Pius LASB from Irate, Swamps hvhf IDM
Autometer Nexus Guages (TT,FP,BP,EGT), 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line, Baldwin PA2818(6637) RR Boots, 26 row 6.0 Tranny & PS Cooler, LarryB's Denso Starter
INFRNL is offline
post #3 of 7 Old 07-11-2013, 05:02 PM Thread Starter
Thanks for the info INFRNL. I'll run that by them, see what they think.
Still open to other suggestions. Thanks.
post #4 of 7 Old 07-12-2013, 08:51 PM
did they give you a copy of the alignment printout? if so post the specs. Try crossing the front tires and see if the pull changes directions. I do alignments alot at work and alot of the time it is a tire pull. If it is a tire wheel shop they most likely have a newer alignment machine. The one we have tells you exactly which bushings to buy to get it in spec and gives you part numbers for napa, moog, ford, etc.
PowerstrokeAaron is offline
post #5 of 7 Old 07-13-2013, 05:09 PM
shawnb99's Avatar
agreed, it my be a tire....
does your arm have any adjustment for caster ? if so, an eccentric may be misaligned and actually trying to twist the axle tubes.
04 F-250 CCSB 4X4 6.0L Auto, tweaked by GEARHEAD
follow link to truck for sale
shawnb99 is offline
post #6 of 7 Old 07-15-2013, 03:57 PM Thread Starter
So I did some measuring and discovered the axle needs to come back to the drivers side about a half inch to be centered. Also the passenger side tire is turned to the right with the steering wheel straight and the driver side wheel straight. Would have thought after 3 alignments they would have picked up on that. The track bar is stock and not adjustable. Do I need an adjustable track bar to fix the axle and then get a new alignment? Thanks in advance.
post #7 of 7 Old 07-16-2013, 08:39 AM
With a 6 inch lift, a dropped pitman arm AND a dropped track bar bracket should be used. The important thing to remember is to keep the track bar and drag link at the same angle.
On a side note, go to a different alignment shop. It staggers the imagination that it took 3 trips and they didn't catch that.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
