Engaging stock overload spring sooner - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Jerrybizzle
post #1 of 10 Old 07-09-2013, 03:12 PM Thread Starter
Jerrybizzle's Avatar
Quoted: 24 Post(s)
I have an 01 f250 that I use to haul my four wheelers on an atv deck in the bed and tow my ~6500 pound camper. Well it squats pretty good loaded up even with the weight distributing hitch setup correctly. Although air bags would be nice, I need a couple other things first (transmission cooler the main one). I am thinking there is a way to engage the factory overload sooner which would keep the rear end up a little better. Been searching around and thinking extended bumpstops to activate the overload would work. These are about 20 bucks for a set of two so would be about 40bucks for 4 and do the trick. Anyone done this? Pics or part numbers would be greatly appreciated. Thanks.
carguy.idaho likes this.
2012 f250CCLB, 35x12.5/17 Kanati mud hogs on race line assault wheels, 2 inch lift
Mini maxx
Jerrybizzle is offline
post #2 of 10 Old 07-09-2013, 03:47 PM
shawnb99's Avatar
try timbrens
04 F-250 CCSB 4X4 6.0L Auto, tweaked by GEARHEAD
follow link to truck for sale
shawnb99 is offline
post #3 of 10 Old 07-09-2013, 03:49 PM
shawnb99's Avatar
Timbren SES | Timbren Industries Inc. Ride Control ProductsTimbren Industries Inc. Ride Control Products
shawnb99 is offline
post #4 of 10 Old 07-10-2013, 04:27 AM Thread Starter
Quoted: 24 Post(s)
Thinking of using these.
http://item.mobileweb.ebay.com/viewi...d=111113491825
Mini maxx
post #5 of 10 Old 07-10-2013, 07:31 AM
You do not want those from ebay, those are bump stops which change when you frame bottoms out. If you are bottomed out, it will make for a harsher ride.
I thought someone made thicker top overload rubbers but do not recall.
Sounds like you need something like the timbrens or airbags.
I would do it right rather than trying to find a cheap temporary solution
You can find good used airbags for decent prices. Worst case, get just the airbags and air them up manually when towing till you csn afford everything else
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)315's
PHP/Beans tuned, 250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system w/RR & FB Delete, Pius LASB from Irate, Swamps hvhf IDM
Autometer Nexus Guages (TT,FP,BP,EGT), 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line, Baldwin PA2818(6637) RR Boots, 26 row 6.0 Tranny & PS Cooler, LarryB's Denso Starter
INFRNL is offline
post #6 of 10 Old 07-10-2013, 09:06 AM Thread Starter
Quoted: 24 Post(s)
I am planning to replace the pads on the overload springs with these so instead of the overload kicking in when it's dropped 4 or so inches it will kick in around a 2 inch drop in rear ride height. Not actually replacing factory bump stops. If its already a riding on the overloads, you think it will ride rougher with the same load still on the overloads?
Mini maxx
post #7 of 10 Old 07-10-2013, 12:47 PM
Why not put a block on top of your leaf spring pack? This would certainly move the over load spring closer to the stops on the frame. Of course you may need a longer set of u-bolts, but it would work.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #8 of 10 Old 07-10-2013, 02:11 PM Thread Starter
Quoted: 24 Post(s)
I will look into that as well. Just weighing some different options. It's not terrible as is, just a bit more squat than I would like. Have a baby due in September so I'm trying not too spend too much money on non essential items.
Mini maxx
post #9 of 10 Old 07-10-2013, 02:37 PM
Ok makes more sense now. The ones you linked would be your cheapest route.
Adding a taller block on top of the leafs would work but you will only gain 3/4" before needing longer ubolts. Ubolts are not cheap plus you would need to figure out what you could use for a taller block.
I think your ride will be the same with this route
INFRNL is offline
post #10 of 10 Old 07-12-2013, 12:47 AM
alaskan155's Avatar
Quoted: 60 Post(s)
here is an idea,
go to the junkyard, and pull some 350 springs(99-07 for direct swap) or 3" wide springs(any 4x4 ford from the 80-current f150-350 should work, minus 04 f150s)
then cut them to length if need be(i would use a angle grinder/saz-saw), and add them to the overload pack, or the main pack, (main pack will lift the truck/firm up ride, like a add a leaf), if you add them to the main pack, it might give enough lift to eliminate the factory block, giving the same height, and increasing the spring capacity, but it will firm up the ride.
might need some new u-bolts(good to replace anyhow, even if you are just going to add a block between the overload and main leafs), and new center pin,
just an idea if you have a local pick n pull and some tools, could be relatively cheap, ive been seeing a few super-duty land in them lately,
but just giving another option
end result would be something like this(just off google)
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
